Dec 14, 2004 - 1:57 PM
Enthusiast Joined Dec 2, '04 From ireland Currently Offline Reputation: 0 (0%) |
Since I got the my celica gt it seems to have flat spots in 1st and 3rd under 3000rpm then theres a high burst of power ! Is this the norm or can anyone surgest how to mend this problem? Thinking of changing sparks leads and using some injector cleaner will this help? Also installed k&n induction kit this seems to have only made it worse! Please help!
Dec 14, 2004 - 2:15 PM
I think a tune-up might help. I know it helped my '88 Celica a lot. It used to always kind of stutter and seem dull below 3,000 RPM and then it picked up, but now it only does that when it's cold and is fine once warm.
Dec 14, 2004 - 2:18 PM
well depending on where in the power band you shift you will feel a diffrenet in the pull.... try shifting at the same rpm at all gears.. that isjust one posalbity (sp)
Dec 14, 2004 - 2:28 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 9, '03 From St. Louis Currently Offline Reputation: 0 (0%) |
You may feel this sensation if you have a leaking vacuum hose or perhaps a bad o2 sensor
-------------------- [img]http://photos-081.facebook.com/n6/081/n15913038_30266081_3342.jpg[/img]
Dec 14, 2004 - 2:43 PM
psssssst its 135hp.
Dec 14, 2004 - 2:45 PM
QUOTE(Supersprynt @ Dec 14, 2004 - 11:43 AM) psssssst its 135hp. [right][snapback]221371[/snapback][/right] What does that have to do with his problem? -------------------- New Toyota project coming soon...
Dec 14, 2004 - 3:56 PM
Enthusiast ![]() ![]() ![]() Joined Aug 29, '02 From New York City, NY Currently Offline Reputation: 1 (100%) |
Wouldn't they have something like the SS's in ireland anyway?
Dec 14, 2004 - 5:23 PM
Enthusiast ![]() ![]() ![]() Joined Nov 27, '03 Currently Offline Reputation: 0 (0%) |
The 135 hp doesn't have anything to do with his power loss. The GT engine isn't too bad at the low RPM's but I would agree that it comes to life around 3000 RPM's, thats when the car gets ready for the power band. Like Coomer suggested, I would get a tune up (spark plugs, cap and rotor, plug wires, etc...) and see if that makes any difference. Also you may want to replace your fuel filter cuz that could be the cause of fuel restriction.
Dec 14, 2004 - 5:57 PM
QUOTE(Supersprynt @ Dec 14, 2004 - 2:43 PM) psssssst its 135hp. [right][snapback]221371[/snapback][/right] ITS A JAP IMPORT 190 BREAK I WAS TOLD BY TOYOTA MECHANIC |
Dec 14, 2004 - 6:18 PM
Chill its humor, i was being a smartass. Poor performance, low hp, get it? No? Everyones so serious.
Dec 14, 2004 - 6:19 PM
![]() Enthusiast ![]() ![]() Joined Dec 3, '04 From torrance, ca Currently Offline Reputation: 0 (0%) |
QUOTE(Supersprynt @ Dec 14, 2004 - 2:43 PM) psssssst its 135hp. [right][snapback]221371[/snapback][/right] dude for 130hp (here in CA) the car picks up pretty fast and has pretty good power delivery up to 80mph and then it starts to run out of horses |
Dec 14, 2004 - 6:21 PM
Wow lets let it go, my bad for making a poor joke.
Dec 14, 2004 - 6:29 PM
Dec 14, 2004 - 6:33 PM
QUOTE(Supersprynt @ Dec 14, 2004 - 6:18 PM) Chill its humor, i was being a smartass. Poor performance, low hp, get it? No? Everyones so serious. [right][snapback]221479[/snapback][/right] JOKE TAKEN |
Dec 14, 2004 - 6:45 PM
I am not so sure what you mean by flat spots.
Dec 14, 2004 - 6:53 PM
QUOTE(Supersprynt @ Dec 14, 2004 - 6:45 PM) I am not so sure what you mean by flat spots. [right][snapback]221488[/snapback][/right] BEST WAY TO DESCRIBE IT U PUT UR FOOT TO THE FLOOR NOTHING FOR 1 OR 2 SECONDS THEN U GET FULL POWER |
Dec 14, 2004 - 6:56 PM
"You get nothing" as in, you barely get much power? Or pressing the pedal has no effect whatsoever until it's been held for 1-2 seconds, or what? More details will help.
Also, turn off the caps lock. -------------------- New Toyota project coming soon...
Dec 14, 2004 - 7:03 PM
QUOTE(Coomer @ Dec 14, 2004 - 6:56 PM) "You get nothing" as in, you barely get much power? Or pressing the pedal has no effect whatsoever until it's been held for 1-2 seconds, or what? More details will help. Also, turn off the caps lock. [right][snapback]221492[/snapback][/right] Very little power at the start seems to get a little better when i fill up with petrol But not much better! |
Dec 14, 2004 - 7:19 PM
that could be 1/2 a dozen things, clogged injectors, faulty pump, poor sparks, distributor...
Dec 14, 2004 - 7:40 PM
I bet it has something to do with your fuel delivery, whether it be pump, filter, or injectors. I would suggest running some fuel system cleaner through on your next FULL gas tank. See how that treats you.
| Lo-Fi Version | Time is now: June 23rd, 2026 - 6:08 PM |
