> Some things you look for when buying a used car, Engine..clutch.etc
post Dec 15, 2004 - 9:45 PM
StaticKnotX
Joined Sep 5, '04
What are some things you check for when you go to buy a used car from a person. Things like making sure everything is connected, wiring is all good, etc. I know diff cars have diff problems. But when test driving it, I hear if you shift to 4th, then keep the RPMs at 1000-1500. After that, floor it. If you see the RPM jump up then fall back down, your clutch is slipping. Is this true? Thanks
post Dec 15, 2004 - 10:42 PM
klr_toy
Joined Feb 18, '03
From Hermiston, OR
yes if it does that the clutch is slipping.
Lo-Fi Version Time is now: August 11th, 2026 - 3:20 PM
