Dec 16, 2004 - 11:49 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 22, '04 From illinois Currently Offline Reputation: 0 (0%) |
I have two 12 inch kicker comp, 8-ohm dual coil enclosed. I have the concept cc-452 amp running it. What i took out of the car was a Bazooka TVB-141 Tri-vent subwoofer which was being ran by a MTX-282 thunder. Now, through research, i think i've found that the MTX amp which i own is more powerful. But the concept amp sounds awesome (at least the speakers). So, my question is, if anyone knows, which amp had more power, and with more power, will my kickers sound better?
-------------------- ![]() The most important lesson I learned from Karate-Dō Kyōshan – “You can not be what you do not believe you are” |
Dec 17, 2004 - 12:01 AM
Enthusiast ![]() ![]() ![]() Joined Aug 18, '04 From St. Louis, Missouri Currently Offline Reputation: 0 (0%) |
more power usually means better sound. if speakers are underpowered, they generally wont sound as good as they can. as far as power, which amp provides more power @ 2 ohms mono?
| Lo-Fi Version | Time is now: September 8th, 2026 - 8:34 PM |
