> who came up with the idea that supra injec., are 360cc?
post Dec 17, 2004 - 9:36 AM
so...anyone know whos idea it was that supra 315cc injectors become 360cc in our cars?
after doing a little research, i noticed that our FP and the na supra fp is the same, its the TURBO that has a lower fp.
this means that those injectors are only good for about 192hp or so @ 100% duty cycle..ill have the printout from RC Engineering scanned into the 'puter and put it up here in a day or so.
i think without a FMU, some of us will be running real close to the edge thinking we're safe..
cant be THAT simple, can it guys??
itchy, if what im thinking is true, man your REAAAALLLY close...
is anyone running a fmu? if so which?
3 Pages V   1 2 3 >
Replies (1 - 19)
post Dec 17, 2004 - 10:07 AM
Drocay
Joined Oct 3, '02
From Va Team 6gc
now thats interesting.
Team 6gc 2005
post Dec 17, 2004 - 11:23 AM
You can say that again, wait you did.
The turbo injectors, arent they 440's like the 3s's? The FP is lower because its a bigger injector. Now IDK what you guys are using to turbo your 5s but if the 7mge injectors fit why not use the 7mgte injectors?
Do the 3s injectors fit?
post Dec 17, 2004 - 11:58 AM
macavely
Joined Nov 4, '02
QUOTE(Supersprynt @ Dec 17, 2004 - 11:23 AM)
[right][snapback]222787[/snapback][/right]
thats what i want to know.... its said that the 3s are to big which i kind understand but at the same time i'm like what the fook ... i want to know if this is just someones guess or proven....
great find manny .....
post Dec 17, 2004 - 1:05 PM
They is most likely aftermarket injectors for the 7mgte so get those and try those.
post Dec 17, 2004 - 1:17 PM
from what understand the "te" injectors are side feed..no go in the 5s rail
post Dec 17, 2004 - 1:19 PM
macavely
Joined Nov 4, '02
so doesn anyone know what else would work? cause for the looks of it... its going to be a no go for anything over 200hp ... which i'm not planning on going over.. but i like to cover my own ass so i don't ware a thong...
post Dec 17, 2004 - 1:27 PM
Could always try adding an additional injector and having a seperate controller for it.
post Dec 17, 2004 - 1:34 PM
macavely
Joined Nov 4, '02
na.. don't think i'll be doing that... .. its more and more looking like it might be custom injectores.... has anyone tried injectors from another maker.. audi .. sabb ... bmw ??
post Dec 17, 2004 - 2:35 PM
redtcel
Joined May 19, '04
From The Coast, New Hampshire
how about this guys, i have some 440's from a 7mgte my buddy gave them to me, i'll try them and see if they work.
post Dec 17, 2004 - 2:36 PM
macavely
Joined Nov 4, '02
sounds like a plan red... let use know ...
post Dec 17, 2004 - 2:38 PM
shid
Joined Jan 8, '04
From LA
QUOTE(presure2 @ Dec 17, 2004 - 2:36 PM)
[right][snapback]222757[/snapback][/right]
Well since the supra comes stop with more hp than that. ...
Thats my probably wrong 2 cents, and the only thing I could add to this discussion
post Dec 17, 2004 - 2:50 PM
redtcel
Joined May 19, '04
cool im playing hookie from work today so it might be today it might be tomorrow but it will be done and i will post results. oh and by the way if you didnt know i am dabbling in the 5sfte now as well.. i have the FREE injectors, FREE intercooler and i have a st165 header... biggrin.gif can i join yer guys' 5sfte club?
post Dec 17, 2004 - 2:53 PM
well since the NA supra is just that, NA the BSFC for that car is less then our application, thats why the numbers seem off.
shid, if you dont have anything worth sayin, just dont say it, you make yourself sound silly otherwise wink.gif
BTW all my math can be checked over @ rc's technical page
its all there and black and white. anyone with a claculator can figure it out...just so you know, the bsfc for the 5sfte is .61 wink.gif
This post has been edited by presure2: Dec 17, 2004 - 3:21 PM
post Dec 17, 2004 - 3:01 PM
macavely
Joined Nov 4, '02
QUOTE(presure2 @ Dec 17, 2004 - 2:53 PM)
[right][snapback]222929[/snapback][/right]
can i add to this ... happy B-day manny .... lol
post Dec 17, 2004 - 3:45 PM
shid
Joined Jan 8, '04
From LA
I'll just go home now
(and I have no idea who first said that)
post Dec 17, 2004 - 4:23 PM
ok guys after checking this all out again, it seems the intial formula that i got from someone on the mr2 board wasnt correct.
the formula goes like this:
injector size 315cc=30lbs per hr X 3.2(80%duty cycleXnumber of cylinders)=96 X .61(brake specific fuel consumtion)=58.56hp per cylinder X 4 =234.24 flywheel hp THIS MATH IS WRONG!!!!!
so thats what we're "safe" up to. after that, who knows..lol
the formula was taken from rc engineering's tech section, so i trust that.
sorry for gettin on ya shid.. just like to try and keep the posts helpful wink.gif
its that rule that mamma always taught me, "if you dont have anything good to say, dont say anything at all" smile.gif
:::EDIT:::chris D from celicatech posted the correct was to do this math. here it is.
You need:
(Inj. Size)*(duty cycle) / (BSFC) = HP/cylinder
(30lb/hr)*(0.8) / (0.61) = 39.344 * 4 cylinders = 157hp
Reported numbers higher than this very likely have a duty cycle higher than this. If you use 100%:
(30lb/hr)*(1.0) / (0.61) = 49.18 * 4 cylinders = 197hp
This also assumes that the base fuel pressure is 42psi or whatever the 315's are rated at.
This post has been edited by presure2: Dec 18, 2004 - 8:36 AM
post Dec 17, 2004 - 4:28 PM
macavely
Joined Nov 4, '02
QUOTE(presure2 @ Dec 17, 2004 - 4:23 PM)
[right][snapback]223001[/snapback][/right]
yea manny but if that exhust isn't right.. and everthing else is working the way it should... it might still be a problem.... i haven't done the math yet.. but i do trust your numbers..... so we should be good... but still you know what i'm worried about...
post Dec 17, 2004 - 7:00 PM
1bwilson
Joined Aug 30, '02
From Maryland
what about the 2jzge? They MAY have a higher cc rating. As for the first person who said 360......well its been a while but.
Years ago when Nuke first started the 5sfTe trend into the celica world he along with many other celica and MR2 owners never could find out the exact #'s. Some sites said 315 some said 360. Most old topics did say there was confusion in the cc rating and both terms were used. I guess over the past 3ish years people either went with 315 or 360. Id find one of Nukes old quotes from c.net but the site has been cleared.
Member of Team 5sfTe
post Dec 18, 2004 - 8:20 AM
ok guys i couldnt get the printout from rc scanned, so i just took a pic of it..here it is. before cleaning in the left column, after in the right... wink.gif as you can see, even at a bsfc of .50, we're gonna REALLY be pushing it..so i go back to my original statement. we're gettting DANGEROUSLY close to the edge with these injectors..
heres a pic of the collection so far, exaust mani. elbow & cat are missing from the pic, theyre at moms for test fitting on the old engine. wink.gif
This post has been edited by presure2: Dec 18, 2004 - 8:39 AM
3 Pages V   1 2 3 >
Lo-Fi Version Time is now: May 15th, 2026 - 10:34 PM
