> Would this be ok?, Please Help!!!
post Dec 17, 2004 - 4:43 PM
gt_driFFter
Joined Nov 29, '04
Hey guys, I'm in a pretty desperate situation and I was wondering if it would be ok to run smaller wheels in the front and the stock ones in the rear? The wheels are only an inch less than stock in diameter and they are about 1/2 inch wider. This would be for 2, maybe 3 months max. I really need to know soon guys!
Thanks!
post Dec 17, 2004 - 4:48 PM
LatinKraze
Joined Oct 22, '03
It will throw of your speedometer a bit and your mpg will decrease a bit if the diameter is smaller.
This post has been edited by LatinKraze: Dec 17, 2004 - 4:48 PM
post Dec 17, 2004 - 4:49 PM
macavely
Joined Nov 4, '02
yea thats ok..
post Dec 17, 2004 - 4:51 PM
Ale_lock
From New York City, NY
QUOTE(macavely @ Dec 17, 2004 - 5:35 PM)
damn i can't find the words to explane it ... but its something i help my cousin with on hit accord back in the day....  its not that hard to do .. they way i'm planning on doing it.. i just have get the pulses to lumnat a small lcd screen and have the light re- reflected back on the the face of the gauges...  ... when i start it up i'll show pictures.. that will explaning it better then i can..
[right][snapback]223013[/snapback][/right]
QUOTE(LatinKraze @ Dec 17, 2004 - 5:48 PM)
[right][snapback]223020[/snapback][/right]
Wouldn't it increase slightly since it's rotating less?!
post Dec 17, 2004 - 5:01 PM
gt_driFFter
Joined Nov 29, '04
I'm talking about handling, stress on the suspension, etc. More critical things then my speedo being off a little.
Thanks,
-Josh
post Dec 17, 2004 - 5:02 PM
macavely
Joined Nov 4, '02
QUOTE(gt_driFFter @ Dec 17, 2004 - 5:01 PM)
Thanks,
-Josh
[right][snapback]223026[/snapback][/right]
your fine... handling might feel a little off but you'll ajust ..
post Dec 17, 2004 - 5:41 PM
LatinKraze
Joined Oct 22, '03
QUOTE(Ale_lock @ Dec 17, 2004 - 1:51 PM)
[right][snapback]223023[/snapback][/right]
If the circumference of the tire was 2 feet and his temporary wheels were 1 foot in circumference, then the smaller wheel would have to rotate twice as much for one rotation of the larger wheel. His speedo would mark twice the distance actualy traveled. The rotation would be greater.
post Dec 17, 2004 - 5:43 PM
LatinKraze
Joined Oct 22, '03
I think it also throws off the rpm. Can anyone confirm this?
post Dec 17, 2004 - 6:37 PM
macavely
Joined Nov 4, '02
QUOTE(LatinKraze @ Dec 17, 2004 - 5:43 PM)
[right][snapback]223039[/snapback][/right]
no i;m sure it doesn't... unless i'm wrong ..
post Dec 17, 2004 - 6:59 PM
Mynzeyes
From Franklin/Nashville, TN
QUOTE(macavely @ Dec 17, 2004 - 5:37 PM)
[right][snapback]223049[/snapback][/right]
RPM is engine revolutions per minute..not anything to do with drive axles or wheels/etc. smile.gif.
AIM==Mynzeyes
post Dec 17, 2004 - 7:17 PM
1bwilson
Joined Aug 30, '02
From Maryland
QUOTE(macavely @ Dec 17, 2004 - 4:37 PM)
Member of Team 5sfTe
post Dec 17, 2004 - 7:23 PM
macavely
Joined Nov 4, '02
damn know can ever tell when i'm joking... i hate all you muthersukers..
post Dec 19, 2004 - 2:33 AM
if the wheel is smaller it will read FASTER since the wheel it self moves faster then the larger rims
IF you measure from TIRE (not rim) the diameter, across the tire
and the diameter is the same as the larger wheel (thinner tires then the smaller)
then you should be good for the most part
LARGER rims make your speedo say that you are going slower
and it can effect your RPM just so you know....14" enkies i redline at stock factory red line
18s i redline before that by 400 rmp
but that is just the RMP gauge off.....i really am at factory redline but because of the wheels it reads lower
This post has been edited by playr158: Dec 19, 2004 - 2:34 AM
post Dec 19, 2004 - 5:17 AM
jgreening
Joined Jan 17, '04
From Illinois
I know speed, odometer and drive ratios are affected by tire size. However, I was under the impression that the RPM guage is metered off the engine, not the wheels.
post Dec 19, 2004 - 10:58 AM
1bwilson
Joined Aug 30, '02
From Maryland
QUOTE(jgreening @ Dec 19, 2004 - 3:17 AM)
[right][snapback]223611[/snapback][/right]
You are correct. RPM's are how fast the crank rotates per minute. I dont think it can cause your RPM's to be off.
post Dec 19, 2004 - 2:10 PM
yes it is off the crank......but it can still mess with your wheels...
aka crank moves tranny which moves wheels wink.gif its all effects eachother and trust me my eyes can see my gauge
post Dec 19, 2004 - 2:17 PM
shid
Joined Jan 8, '04
From LA
While the guage might be differen't (unlikely) there's no way wheel size changes can effect the actual physical RPMs your engine puts out. It's not like your torque curve or powerband are going to shift or anything.
Your handling will get worse; and you'll scrap on a lot of bumps.
post Dec 19, 2004 - 11:07 PM
jgreening
Joined Jan 17, '04
From Illinois
aka crank moves tranny which moves wheels  its all effects eachother and trust me my eyes can see my gauge
Player, if its off the crank, then the size of the wheels makes no difference. The guage would simply be measuring engine RPM's and the affect of those RPM's through the drivetrain (tranny, wheels, etc) would have no effect. The only way it could possibly affect the tach is if the tach was measured off the wheels and then the ECU computed the RPM's given the gear and wheel speed. Even this makes no sense because you could rev up to 100mph and then take your foot completely off the accelerator. If it were measured off of wheel speed, the tach would not drop - which of course it does.
post Dec 20, 2004 - 12:04 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Wheels size does NOT affect RPMs... it does affect speed and speedometer/odometer. The speedo gear drives the speedometer and odometer, electronically or mechanically, both signaled off of the tranny so bigger/smaller wheels/tires do affect that to some degree only to the drive wheels. RPM is usually a signal from the distributor, crank sensor, or something on the engine, so RPMs will feel no effect from larger/smaller wheels/tires. The RPM gauge is not connected to anything relating to drivetrain aside from engine load.
This post has been edited by Kwanza26: Dec 20, 2004 - 12:05 AM
post Dec 20, 2004 - 6:02 PM
mwhahaha then my st is just gay then lol.....
but you won't scrape with bigger rims? with 14" rims i was like 2" above the asphalt with 18s i'm 6" above asphalt so no scrape wink.gif
and not to be a dick....but GT driffter....you need to change your sig...thats just an asshole thing to do.....your a sick, foul, and discusting person if your going to support that idea...personnally i think that if you think thats funny, or cool you should shoot yourself with that gun and do the people with those problems a favor...oh and me a favor for that matter
This post has been edited by playr158: Dec 21, 2004 - 12:47 AM
Lo-Fi Version Time is now: July 8th, 2026 - 3:04 AM
