Dec 19, 2004 - 5:24 AM
Enthusiast Joined Dec 19, '04 From Kansas Currently Offline Reputation: 0 (0%) |
I have a '95 ST Liftback 5 speed (AT200) with a bad 7AFE. I kinda hate to replace it with another anemic 7AFE but I'm not up to the 3SGTE swap. I see no mention of a 7AFE to 5SFE swap on the boards except that it is not plug-and-play and it is as much trouble as a 4AGE 20V or a 3SGTE.
MY question: What is required to upgrade my AT200 from 7AFE to 5SFE, and what year or years ST204 GT should I select as a donor car? I'm hoping to hear I'll need the ECU and engine wiring harness from the ST204 and that the engine will bolt up to my transaxle. If the swap requires harness splicing and pinout changes I'll probably just settle for 110 HP and stick with the 7AFE. Thanks for any info. |
bigblock261 7AFE to 5SFE ? Dec 19, 2004 - 5:24 AM
jgreening It wont bolt up to the car or the trans and you wi... Dec 19, 2004 - 6:24 AM
bigblock261 Bummer. I guess I'm destined to the low power... Dec 19, 2004 - 8:50 AM
Digndoug QUOTE(bigblock261 @ Dec 19, 2004 - 1:50 PM)Bu... Dec 19, 2004 - 1:28 PM
Chrobis To change over the 5s all you would have to change... Dec 19, 2004 - 2:07 PM
Chrobis But on a side note, a 3s-swap will end up costing ... Dec 19, 2004 - 2:11 PM
bigblock261 I see that swaps are a topic of much discussion, a... Dec 19, 2004 - 2:48 PM
Chrobis Yes, these shops do exist.... But the problem is t... Dec 19, 2004 - 3:45 PM
bigblock261 Thanks for the insight. It helps. On this one I... Dec 20, 2004 - 5:58 AM
Hanyo the swap should not be that hard.. get a totaled g... Dec 20, 2004 - 6:23 AM
BBoYRuGGeD just adding a suggestion but u can also do what fr... Dec 20, 2004 - 6:52 AM
bigblock261 UPDATE: We purchased a '94 7AFE from a wreckin... Mar 28, 2006 - 1:29 AM
95CelicaST Nice to hear it is up and running. You could have ... Mar 28, 2006 - 3:07 AM
bigblock261 QUOTE(95CelicaST @ Mar 28, 2006 - 3... Mar 28, 2006 - 3:21 AM
95CelicaST Dr. Tweak could have done the wiring for 350 I thi... Mar 28, 2006 - 3:38 AM
j0e_p3t go with the 4age. i think that would be easier tha... Mar 28, 2006 - 7:04 PM![]() ![]() |
| Lo-Fi Version | Time is now: July 30th, 2026 - 5:59 AM |
