> Heat Shield Painted, Anyone?
post Dec 26, 2004 - 5:22 PM
sapperk
Joined Mar 9, '03
From Orting, WA
Does anyone have their heat shield painted? ive painted mine with that paint for 1600* and it still burnt off. Did i do something wrong?
post Dec 26, 2004 - 5:25 PM
macavely
Joined Nov 4, '02
what was your pre work like?
post Dec 26, 2004 - 6:00 PM
i shot mine with the tipical 1200 deg paint. it never burned off.
post Dec 26, 2004 - 6:27 PM
sapperk
Joined Mar 9, '03
From Orting, WA
im gonna try again, im also going to wrap the pies with thermo wrap.
first time i stripped it with a dremel all the way down to where it was shiny, then i primed it with the 1200* primer, i dont think i let it cure long enough, im gonna do it again with 1200* alluminum
post Dec 27, 2004 - 4:25 PM
97GTinKC
From KC
After prepping it and cleaning it, I use the non-flammable BrakeKleen for a final wipedown, (you can use laquer thinner or alcohol, but only outdoors and let it ALL evaporate before getting any flame near it) I then heat it lightly with a propane torch (parts off the car of course) just enough to boil out any oil film left in the metal, you can usually see the oil evaporating as you move the torch slowly, then paint it b4 it cools off too much. this makes the paint stick much better.
post Dec 27, 2004 - 5:32 PM
sapperk
Joined Mar 9, '03
From Orting, WA
alright i painted it, now im gonna let it dry for like a day, then ive done some research and ive learned baking it at about 300* for a little should help it alot. Well see. in a day
post Dec 28, 2004 - 12:55 PM
dahoman9
Joined Mar 1, '04
From Louisville, KY
you got any pictures?
post Dec 28, 2004 - 1:49 PM
sapperk
Joined Mar 9, '03
From Orting, WA
is it a pain to take off the valve cover.
post Dec 29, 2004 - 8:39 AM
sapperk
Joined Mar 9, '03
From Orting, WA
i painted it, let it dry for a day, then i put it in the oven to test it at 300* and after about an hour the paint is slowly bubbling up a little?
post Jan 10, 2005 - 2:14 PM
97GTinKC
From KC
possibly boiling the oil film out from under the paint, see my prev post above.
Talked to a local powder-coat guy, he says he now has high-heat powders that will stand up to exhaust heat, I dont believe it would on an exhaust manifold or header on a lean-burning computer controlled engine, need to send them to JET-HOT for ceramic coating, but it should work great on heat shields and valve covers etc.
This post has been edited by 97GTinKC: Jan 10, 2005 - 2:19 PM
Lo-Fi Version Time is now: July 8th, 2026 - 8:49 AM
