> alarm + lights help, quick plz
post Dec 28, 2004 - 10:54 PM
Celicaca
Joined Feb 3, '04
From North Carolina
so i got my alarm installed. when the parking lights or headlights are not on, and i unarm/arm my alarm, the lights flash as supposed to. when my alarm goes off, the lights flash also.
BUT when my headlights are turned on (like when u keep ur headlights switched on and you remove your key and exit the car, they turn off) and i arm or disarm my car, the lights do not flash; same as when the alarm goes off
so what i want to know is what the installers did wrong exactly and how to correct it because it makes more sense for the lights to flash @ night (when the headlights are on) rather than in daylight (when they are on the off position)
if someone could respond by tomorrow morning id be very grateful, thanks
post Dec 28, 2004 - 10:58 PM
madmods
Joined Mar 19, '04
From Scottsdale, Az
What kind of alarm do you have. Dei are more specialitys
post Dec 28, 2004 - 11:34 PM
macavely
Joined Nov 4, '02
it sounds like its just a matter of where you placed the connections...to know how to fix the problem .. would have to see his work... but remeber if your not happy just take it back... and tell them what you want....
post Dec 29, 2004 - 12:35 AM
mikew04
Joined Feb 19, '04
From austin tx
my keyless entry that i installed myself does this as well, it never really bothered me tho. when you leave your lights on with the ignition off and open the door, it probably opens the ground for you parking lights. during the day when i cant see the lights, or if i leave my headlights switched on at night, i usually just listen to make sure my doors got locked.
post Dec 29, 2004 - 6:56 AM
Hanyo
Joined Aug 16, '03
From Bay area
get out a mulimeter and measure the volts that come out from the parking lights wire on your alarm.
is it 12 volts? or is it a negative trigger?
post Dec 29, 2004 - 9:07 AM
Celicaca
Joined Feb 3, '04
From North Carolina
QUOTE(mikew04 @ Dec 29, 2004 - 5:35 AM)
[right][snapback]227593[/snapback][/right]
but my other alarm flashed the lights given the same situation. so doesnt that mean they just hooked it up wrong?
Lo-Fi Version Time is now: September 21st, 2026 - 12:43 AM
