Jan 3, 2005 - 5:20 AM
well as some of you might know about me? I don't belive in that change your oil at 3000 miles BullSugar ....
I check my dip stick ever other day to check for any change in color.... just wanted to know how offten do ya'll check your oil ??? -------------------- |
Jan 3, 2005 - 5:23 AM
Enthusiast ![]() ![]() Joined Nov 3, '04 From Colorado Currently Offline Reputation: 0 (0%) |
They say full synthetics can go 18,000 miles without being changed, as long as they are topped off, and oil filter is changed 3,000 miles.. But I just change my oil at 3,000 miles, unless I do something stupid, like mis-downshift.. *cringe*
Jan 3, 2005 - 8:52 AM
you ever look at your oil after 3,000miles? it looks nothing like it did the day you put it in. aslo, most oil filters are made out of cardboard...you think thats going to last a year or more?
if you are being cheap, then just buy crap oil ($1.50ish a bottle), but change it often. oil is the life blood of an engine! -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jan 3, 2005 - 9:12 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 3, '02 From Va Team 6gc Currently Offline Reputation: 1 (100%) |
i change mine every 5,000 and its only cause i'm using mobile 1 synthetic. Filter i got K&N so i recharge it every time i change oil.
-------------------- ![]() All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
Jan 3, 2005 - 1:44 PM
Enthusiast ![]() Joined Jul 30, '04 From colorado Currently Offline Reputation: 1 (100%) |
i change mine every 2000 miles! be nice to your engines!
Jan 3, 2005 - 2:33 PM
I change mine every 2k-2500 . Norm its just cause it seems forever and i dont drive a ton. But yeah u should def change ur oil often. I notice a dif in power every time i change it. also with older engines it will keep em runnign longer and smother, i also add a ring conditoner as well.
doh, to awnser ur question, i check every week. This post has been edited by Digndoug: Jan 3, 2005 - 5:50 PM |
Jan 3, 2005 - 2:37 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 8, '04 From LA Currently Offline Reputation: 0 (0%) |
I uh.... err... didn't change my oil for almost a year once.. with an oil leak.. uhh.. when I finally got around to it.. uhh.. the dipstick was.. uhh.. totally dry.. err look. I don't wanna talk about it ok? I check it every month, and I change it every 3k or so... now.
Jan 3, 2005 - 11:55 PM
Enthusiast ![]() ![]() Joined Nov 4, '03 From Vancouver, Canada! Currently Offline Reputation: 0 (0%) |
i do mine every 5000km..... it says on my hood it is only needed every 12,000km..... silly toyota
i tried that once and the oil looked like poop..... never again will i listen to toyota stickers. I will even take a pic of the sticker if no one believes me This post has been edited by wind: Jan 3, 2005 - 11:55 PM |
Jan 4, 2005 - 12:48 AM
Super Thick Black Motor Oil... last for a good 10k miles with normal driving ...
Jan 4, 2005 - 12:52 AM
Enthusiast ![]() ![]() ![]() Joined Aug 31, '02 From KC Currently Offline Reputation: 0 (0%) |
I try to remember to check it at least once a month, I change it once a year or every 35,000 miles, change the filter every 4 months or 5000, but I use Amsoil series 2000 0W30, I wouldn't try that with any other oil,,,
last car had Amsoil its entire life and got 161,000 miles b4 I lost all the water and cracked the head, couldn't measure any wear in the motor, even the end-gap on the rings was only .003 out of spec, (the NEW aftermarket ones were .004 out, had to buy orig. MAZDA rings, they were perfect .011 for spec of .008-.014, so NO wear in the cylinders or anywhere else. So as long as I run a good synthetic, I see no reason to needlessly change my oil too often. This post has been edited by 97GTinKC: Jan 4, 2005 - 12:54 AM |
Jan 4, 2005 - 1:52 AM
Enthusiast ![]() ![]() ![]() Joined Nov 27, '03 Currently Offline Reputation: 0 (0%) |
QUOTE(shid @ Jan 3, 2005 - 7:37 PM) I uh.... err... didn't change my oil for almost a year once.. with an oil leak.. uhh.. when I finally got around to it.. uhh.. the dipstick was.. uhh.. totally dry.. err look. I don't wanna talk about it ok? I check it every month, and I change it every 3k or so... now. [right][snapback]229465[/snapback][/right] hehe |
Jan 4, 2005 - 2:21 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 13, '02 From Blairstown, New Jersey Currently Offline Reputation: 6 (100%) |
I'm pretty religious about checking my oil color and level....I put fresh Castrol GTX 10w-30 in along with a good filter every 2500-3000 miles, sometimes more often than that. If it looks like its not clean enough to protect the engine, then I drain it right away....if I'm not too lazy.
-------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
Jan 4, 2005 - 2:31 AM
When i used to care... usually on a weekly basis. Now... after I put in new oil...
-------------------- "It's ok to be naked girl... I'm an artist!"
Jan 4, 2005 - 8:27 AM
You guys change ur oil less than 3000 miles? If I did that i'd be changing it almost every 2 weeks - completely unnecessary.
Jan 4, 2005 - 1:15 PM
QUOTE(Supersprynt @ Jan 4, 2005 - 1:27 PM) You guys change ur oil less than 3000 miles? If I did that i'd be changing it almost every 2 weeks - completely unnecessary. [right][snapback]229729[/snapback][/right] Well some people like me, i dont drive far at all. I drive at the most 12k a year, and thats with taking 3-4 very big road trips. I prolly drive around 8k a year. I live right down the street from my college, and i work from home, and if i get a second job its no more then 5-10 miles away. Therefor it makes sence for me. cause im still only changing my oil every 3-4 months. And i dont know bout u guys but i love just working on my car. |
Jan 4, 2005 - 2:29 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 16, '04 From UK Currently Offline Reputation: 0 (0%) |
Most decent fully synths can run to 25-30K without breaking down. 10K should be no problem.
I change mine every 4.5K, and I drive the hell out of it. Oil in a GT-Four leads a hard life. And it looks pretty good when it comes out. Changing fully synth in a 5S-FE every 3K is pure insanity IMHO. -------------------- JDM ST205
Blitz Spec NUR Exhaust, somewhere over $1000 Needing another one 18000 miles later, bloody annoying. |
| Lo-Fi Version | Time is now: March 25th, 2026 - 9:39 AM |
