> 5sfte turbo oil line, reducing oil pressure...
post Jan 9, 2005 - 1:31 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
allright i've been searching and reading up. it looks like when the 5sfte conversion is done there seems to be a problem with oil consumption and leakage through the turbo which in turn could cause damage. now if i'm using -4 an line which is 1/4" for the oil feed line and a -10 an oil return line which is 5/8", is this setup going to be allright. is there going to be too much oil pressure. i've heard of people putting a valve on the line to reduce the pressure or even crimping the stock oil line to reduce some of the pressure. for all you other 5sfte's out there what did you guys do for your oil situation?
Lo-Fi Version Time is now: September 5th, 2026 - 6:05 AM
