Jan 9, 2005 - 10:52 PM
Enthusiast ![]() ![]() ![]() Joined Sep 10, '03 From Santa Barbara, CA Currently Offline Reputation: 0 (0%) |
Just over a week ago I noticed that the celica starts to shake alot when im going fast and i push on the gas pedal... the whole car just shakes violently... It's fine when im just coasting but when i push down the gas it starts to shake really bad. It started out doing it when i was going about 60mph, but today it started doing it at like 40... whats wrong?
Jan 9, 2005 - 10:58 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
uhmmm i know in a rear wheel drive vehicle that that problem would be the u joints but in the celi i'm not sure on that one. it's not the tires off balance cuz it would shake when you take the foor off the pedal.... does it do it in any other gear at high rpm?
This post has been edited by rjbibeau: Jan 9, 2005 - 10:58 PM -------------------- ![]() |
Jan 9, 2005 - 11:01 PM
QUOTE(rjbibeau @ Jan 9, 2005 - 7:58 PM) uhmmm i know in a rear wheel drive vehicle that that problem would be the u joints but in the celi i'm not sure on that one. it's not the tires off balance cuz it would shake when you take the foor off the pedal.... does it do it in any other gear at high rpm? [right][snapback]231817[/snapback][/right] it does it starting at about 40mph so i guess that would be 3rd gear and 4th gear.. its an automatic its always shaken a little bit but just recently its gotten really bad This post has been edited by jojobombiest: Jan 9, 2005 - 11:02 PM |
Jan 9, 2005 - 11:03 PM
does it throw a check engine light at all??? it's prob the torque converter. do you have enough atf fluid in there?
Jan 9, 2005 - 11:13 PM
QUOTE(rjbibeau @ Jan 9, 2005 - 8:03 PM) does it throw a check engine light at all??? it's prob the torque converter. do you have enough atf fluid in there? [right][snapback]231823[/snapback][/right] The light doesn't come on at all... |
Jan 9, 2005 - 11:16 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 22, '04 From illinois Currently Offline Reputation: 0 (0%) |
check your engine mounts
-------------------- ![]() The most important lesson I learned from Karate-Dō Kyōshan – “You can not be what you do not believe you are” |
Jan 9, 2005 - 11:24 PM
ya engine mounts could be it too... good one
Jan 9, 2005 - 11:54 PM
yeah i agree...most of the time if the engine runs good but the car shakes, then its the motor mounts.
Jan 10, 2005 - 12:19 AM
OK I'll check that. thanks for the help
Jan 10, 2005 - 12:26 AM
Enthusiast ![]() ![]() ![]() Joined Nov 27, '03 Currently Offline Reputation: 0 (0%) |
If the engine shakes violently under load its most likely the Engine mounts. Tranny could have something to do with it but very unlikely.
Jan 10, 2005 - 2:47 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) |
Get your wheels aligned?
This post has been edited by CheesyLobster: Jan 10, 2005 - 2:47 AM |
Jan 10, 2005 - 3:41 AM
QUOTE(CheesyLobster @ Jan 9, 2005 - 11:47 PM) Get your wheels aligned? [right][snapback]231894[/snapback][/right] and balanced vibration at speed is almost always due to the tires being out of balance -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
Jan 10, 2005 - 12:25 PM
Enthusiast ![]() ![]() Joined Feb 18, '03 From Hermiston, OR Currently Offline Reputation: 0 (0%) |
might check your axles. When mine went out they were fine coasting but under load you could really feel it. Wasn't bad at first but after awhile they got a lot worse and it was definetly time to change them. just a thought
Jan 10, 2005 - 12:39 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 4, '03 From Kirkland, Washington Currently Offline Reputation: 0 (0%) |
wheels might be bent. i bent mine and havent fixed them and my car shakes. Sucks in the rain cuz im all over the place like a drunk
-------------------- Cruisin down the street in my Infiniti...always lookin for my next trip to Sin City
Jan 10, 2005 - 3:04 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Sep 18, '04 From Manitoba, Canada Currently Offline Reputation: 1 (100%) |
happens out here if you get assloads of snow by your brakes/wheels, but i'm assuming you don't have that problem...
Jan 10, 2005 - 3:15 PM
Enthusiast ![]() ![]() Joined Aug 22, '04 From Menomonie, WI Currently Offline Reputation: 0 (0%) |
its either the mounts for axles...if the tire is out of balance, it would still shake when its coasting. my bet is the axles personally....just replaced mine a month ago.
Jan 10, 2005 - 4:43 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 3, '02 From Va Team 6gc Currently Offline Reputation: 1 (100%) |
QUOTE(97sccelica @ Jan 10, 2005 - 3:41 AM) QUOTE(CheesyLobster @ Jan 9, 2005 - 11:47 PM) Get your wheels aligned? [right][snapback]231894[/snapback][/right] and balanced vibration at speed is almost always due to the tires being out of balance [right][snapback]231908[/snapback][/right] Yup if your car steers in a given direction other than straight when u let go of the wheel then u need alignment. if it shakes than u need balance. If its not either check your mounts. -------------------- ![]() All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
| Lo-Fi Version | Time is now: August 27th, 2026 - 12:41 AM |
