> deleted
post Jan 15, 2005 - 11:48 PM
hioctane
Joined Nov 26, '02
deleted
This post has been edited by hioctane: Jul 31, 2005 - 1:07 PM
post Jan 16, 2005 - 1:19 AM
creis
Joined Jan 10, '04
From Shoreline, WA
e-mail, like hotmail, or e-mail through your service providor?
Looks like you can get on the internet, so its probibly not hotmail or something liike that, I'm guessing you have it though your providor, so what is exacly going wrong, wont log on, or cant get to the site?
post Jan 16, 2005 - 1:51 AM
hioctane
Joined Nov 26, '02
deleted
post Jan 16, 2005 - 1:54 AM
coustoe
Joined Sep 18, '02
From Northern, Virginia
1. check your firewall settings on your router
post Jan 16, 2005 - 1:59 AM
hioctane
Joined Nov 26, '02
deleted
This post has been edited by hioctane: Jul 31, 2005 - 1:06 PM
post Jan 16, 2005 - 2:06 AM
coustoe
Joined Sep 18, '02
QUOTE(hioctane @ Jan 15, 2005 - 11:59 PM)
QUOTE(coustoe @ Jan 15, 2005 - 11:54 PM)
[right][snapback]234291[/snapback][/right]
how do i do that?
[right][snapback]234294[/snapback][/right]
see the ip address assigned to it on your subnet, type ipconfig, it should be the ip with the default gateway.
type the ip address in your browser, it will ask for login and password, use your user manual to look up the login (default is usually administator), look on the back of your router for a reset button, reset your router or look in manual to reset the password.
post Jan 16, 2005 - 2:16 AM
hioctane
Joined Nov 26, '02
deleted
post Jan 16, 2005 - 2:21 AM
hioctane
Joined Nov 26, '02
deleted
post Jan 16, 2005 - 4:39 AM
jojobombiest
Joined Sep 10, '03
From Santa Barbara, CA
for my router u type http://192.168.1.1 and it works. then the username is "admin" and there was no password. but mine is linksys... might be different. thats how u get into your router but im not sure how to check the firewall from there...
This post has been edited by jojobombiest: Jan 16, 2005 - 4:40 AM
post Jan 16, 2005 - 6:14 AM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
that ip address is your default gateway. you can check it by opening a console by typing cmd in your run box in the start menu (assumin youre running 2000 or above). when you have the DOS screen, type ipconfig/all and see what the number is for your defualt gateway. put that number in your explore bar.
is this the only problem youve noticed after installing this router? a little more info in general would help.
post Jan 16, 2005 - 12:33 PM
Ale_lock
From New York City, NY
Or just mention which router you have & then you can be supplied with the default gateway ip & usr/pass for that specific brand...
post Jan 16, 2005 - 12:51 PM
hioctane
Joined Nov 26, '02
deleted
This post has been edited by hioctane: Jul 31, 2005 - 1:05 PM
post Jan 16, 2005 - 1:19 PM
Ale_lock
http://192.168.0.1 user: admin pass: *blank*
Lo-Fi Version Time is now: August 24th, 2026 - 5:38 PM
