> Rear Disk Brake Conversion, Trying to Install, Major Problems, Help!
post Jan 16, 2005 - 1:13 AM
coustoe
Joined Sep 18, '02
From Northern, Virginia
K, spent all yesterday trying to install my rear disk brakes on my st.
Having problems:
1.emergency brakes will not work unless i pull additional wiring up through the e brake handle and use vise grips to keep the line in place, there seems to be tons of slack, and yes I've used the parking brake adjuster inside the parking brake shoe.
2. Caliper brake line from the junkyard has rubber hose cut off and thus no terminating screw or nut connection to connect to st brake lines, Question: can you by the GT caliper line and mate it to st brake line system?. Also I was thinking of using a hose connector to mate the caliper cut rubber line to the st brake system. Though I do not know if the simple brass connector will handle the force running through the lines without breaking.
- coustoe   Rear Disk Brake Conversion   Jan 16, 2005 - 1:13 AM
- - Kwanza26   For the e-brake situation... I can't say. i...   Jan 16, 2005 - 1:25 AM
|- - coustoe   QUOTE(Kwanza26 @ Jan 15, 2005 - 11:25 PM)For ...   Jan 16, 2005 - 1:48 AM
|- - coustoe   QUOTE(Kwanza26 @ Jan 15, 2005 - 11:25 PM)For ...   Jan 17, 2005 - 9:22 PM
|- - Kwanza26   QUOTE(coustoe @ Jan 18, 2005 - 2:22 AM) cant...   Jan 17, 2005 - 9:27 PM
- - Rjb23   Did you try searching yet, I remember reading some...   Jan 16, 2005 - 6:24 AM
- - Rjb23   Yea read the how-to it says parking brake cable fr...   Jan 16, 2005 - 6:26 AM
|- - coustoe   QUOTE(Rjb23 @ Jan 16, 2005 - 4:26 AM)Yea read...   Jan 16, 2005 - 10:00 AM
- - Rjb23   Ok just was making sure =) Here is the thread i ...   Jan 16, 2005 - 7:09 PM
- - Jeremy1210   well if the ebrake cable isn't working and you...   Jan 17, 2005 - 12:02 PM
|- - coustoe   QUOTE(Jeremy1210 @ Jan 17, 2005 - 10:02 AM)we...   Jan 17, 2005 - 9:18 PM
|- - coustoe   QUOTE(Jeremy1210 @ Jan 17, 2005 - 10:02 AM)we...   Jan 17, 2005 - 9:23 PM
- - Jeremy1210   yeah, the ST lines do not fit at all. You will hav...   Jan 18, 2005 - 9:41 PM
|- - coustoe   QUOTE(Jeremy1210 @ Jan 18, 2005 - 7:41 PM)yea...   Jan 18, 2005 - 9:47 PM
- - playr158   yea custoe just order the stock GT piece we looked...   Jan 18, 2005 - 9:50 PM
- - coustoe   ahhh, looking at the tires again in the rear and t...   Jan 20, 2005 - 5:21 PM
- - coustoe   talked to the performance parts guy again today, s...   Jan 20, 2005 - 5:30 PM
- - Ve1Ls1dEvolutioN   hi...anyone here with an ST converted their front ...   Feb 3, 2005 - 4:33 PM
- - Jeremy1210   I want to do that its not that hard. All you need ...   Feb 3, 2005 - 10:34 PM
- - S_C_M   You also need the GT caliper mounting brackets, an...   Feb 4, 2005 - 11:24 PM
- - coustoe   not having all the parts is hard, then if you scre...   Feb 5, 2005 - 7:26 PM
Lo-Fi Version Time is now: September 18th, 2026 - 6:16 AM
