> Winter problem, what do you think it can be?
post Jan 16, 2005 - 11:05 AM
HaRv3sTeR
Joined Nov 22, '03
From Tracadie-Sheila, NB (Canada)
In winter, if I start the car and dont let it run for 15min (minimum) before driving it. Sometime, the car dies when Im about to go. I know it's not good for the car to drive it when the engine is still cold but my case is not normal because sometime it does that even I waited like 10-15min. My battery is 1 year old (1000 ampere)...spark plugs are 6 month olds...dont have any 'Check Engine' light in the dash...I wonder if it can be the wiring (because I didnt changed it since I have my car). What do you guys think? confused.gif
TIA for your help
post Jan 16, 2005 - 12:38 PM
could be your gas lines have a little water and its freezing, add some drygas see if that helps.
15mins is alot tho. Usually I leave it for 5.
post Jan 16, 2005 - 11:40 PM
HaRv3sTeR
Joined Nov 22, '03
QUOTE(Supersprynt @ Jan 16, 2005 - 5:38 PM)
[right][snapback]234402[/snapback][/right]
thx...ive tried that this morning...ill let u know if it helps
post Jan 17, 2005 - 11:16 AM
Snarfer
Joined Dec 2, '03
From Virginia
if your car takes that lone to warm up you might want to look at the thermostat
actually i just saw that you live in canada, do you have to use a block heater up there?
This post has been edited by Snarfer: Jan 17, 2005 - 11:17 AM
post Jan 17, 2005 - 12:26 PM
1900WattCelica
Joined Jul 7, '04
From Germantown, WI
Yea id say it may be water in your gas lines freezing up.
By the way...this post belongs in Engine/Transmission/Performance or General Discussion; Not Interior/Audio/Electrical/Wiring wink.gif
post Jan 17, 2005 - 12:46 PM
HaRv3sTeR
Joined Nov 22, '03
QUOTE(1900WattCelica @ Jan 17, 2005 - 5:26 PM)
[right][snapback]234700[/snapback][/right]
sorry...i posted this in here because at the first time...I tough the problem might be a bad wiring or a short in it ....moderators can move it I dont care
post Jan 17, 2005 - 12:49 PM
1900WattCelica
Joined Jul 7, '04
From Germantown, WI
post Jan 17, 2005 - 3:40 PM
exxtractor
Joined Mar 31, '03
From BC
firstly they should ticket you for letting a car idle for 10 to 15 minutes before not driving it. All you are doing by idling a car is wasting gas, and money, you really aren't stressing your engine much more than starting it and driving off. The best way to warm a car up is to drive it. You could idle a car for 10 to 15 minutes and not have the engine temp indicator move, or you could drive it for less than 5 minutes and see the indicator move. In regards to your problem, not sure but I use to drive a volvo that stalled when it was cold and put into reverse bacing out of the garage, unless you kept the revs up. Doubt its water in your gas line, since the local stations often have winter gas... but you could try another gas station, and or a different blend.
post Jan 17, 2005 - 5:44 PM
DamDirtyApes
Joined Apr 22, '04
From Rhode Island
i idle my car for 10 mins and the gauge is almost up to the normal spot. even if its 20 degrees out
post Jan 17, 2005 - 6:13 PM
Newbie
Joined Nov 3, '04
From Colorado
Have you checked your transmission fluid? It does go through the torque converter, ya know.. Otherthan that, you can always try popping off the vacuum tube to your IAC, so it idles at 1500RPMs.. tongue.gif
post Jan 17, 2005 - 11:40 PM
spunky393
Joined Apr 22, '04
From illinois
I start my car (it's been 8 degree's around here lately) and while sitting in it, i manage my books and whatever else around, and wait for the rpm's to move down from 2000 rpms (full choke in the temp.) Then i drive away, ****ing before 2500 rpms, that's the way to do it
post Jan 18, 2005 - 4:32 AM
Newbie
Joined Nov 3, '04
From Colorado
I wait a full minute or 2, then drive.. I shift before 2000 RPM's though..Then again, the cold isn't that bad compared to other places..
Lo-Fi Version Time is now: August 26th, 2026 - 3:00 AM
