> Suspension question, need this quick, no research time
post Jan 20, 2005 - 3:47 PM
spunky393
Joined Apr 22, '04
From illinois
I need help quickly. What's the best suspension setup someone could buy with money. I'm talking right down to completely not having a stock suspension setup left on my car. Please help quickly, and i'll take anybodies opinion. Please, when you argue, and please do argue, explain why you are arguing, and don't just do it for the heck of it. I appreciate it, lets here it 6GC
post Jan 20, 2005 - 5:55 PM
BLINKYxMUNKEY
Joined Nov 12, '03
From Crestview, Florida
i want to say Tein SS. it runs about 1200$
FlickR
post Jan 20, 2005 - 6:00 PM
TRD6GC
Joined Nov 17, '03
Complete coil-over setups are the best. Like Tein, which only make the Super Street Coil-overs for our car. Also i believe Tanabe makes a setup like this also. However this will run you around $1400. If you want something cheaper then go with ground control coil-overs that are about 400 and then you need to buy new struts like KYB GR-2's, which arent that great if you want the best. Then you should change your strut mounts which i havent found for our cars yet. And then there is much more if you want your suspension not to be stock at all.
post Jan 20, 2005 - 11:01 PM
Junior
Joined May 5, '03
From Toronto
I have to say it, there is no such thing as best. Some things are just ****, but the rest of the stuff has to match the driver and the way they interact helps, plus conditions. Have to take into accound the amount of rebound and compression, if you like to drive with oversteer or understeer.
post Jan 25, 2005 - 5:35 PM
crumpdogg
Joined Jan 25, '05
From Hotlanta
In stock form, a front wheel drive car, will always understeer. The only real way to fix that is with a stiffer rear swaybar. As for the suspension travel and handling characteristics, nothing will beat a true coil-over setup.
It really boils down to your budget.If you want a full race suspension, go with one of the Jap coil-over setups. If you want spirited handling and a good road feel, go with an adjustable strut, lowering spring, and swaybar set. It's really up to you.
Or, if $$ is no option, go to the dealer and buy the stock components. biggrin.gif
post Jan 26, 2005 - 2:40 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
QUOTE(TRD6GC @ Jan 20, 2005 - 11:00 PM)
[right][snapback]236233[/snapback][/right]
are you talking about the pillow ball upper mount cuz here's the site for em their like 223 for the pair for the front. you don't need aftermarket ones for the rear cuz it's just a fixed mount with a bushing. there was a post about this and it wasn't displayed on some site but i found em. they aren't that expennsive. they even have camber adjustments for it.
pillow ball upper mount set
This post has been edited by rjbibeau: Jan 26, 2005 - 2:41 PM
post Jan 27, 2005 - 2:52 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
what noones gonna give me props for finding this awesome info haha
post Jan 27, 2005 - 5:33 PM
turboinduction
Joined Feb 25, '04
From Wisconsin
QUOTE(rjbibeau @ Jan 27, 2005 - 1:52 PM)
[right][snapback]239127[/snapback][/right]
that is so sweet I wanna crap my pants.
-Ti
(ninja line)
post Jan 28, 2005 - 2:19 AM
soltrain
Joined Aug 19, '04
From Berkeley
I hear that JIC Magic coilovers are equal to/better than the Teins. I believe they run about 900 or so. ~supposively they're muy adjustable
This post has been edited by soltrain: Jan 28, 2005 - 2:20 AM
post Jan 29, 2005 - 3:58 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
QUOTE(rjbibeau @ Jan 26, 2005 - 7:40 PM)
[right][snapback]238596[/snapback][/right]
I dont understand what these are for or do? some one can explain?
post Jan 29, 2005 - 9:41 PM
BLINKYxMUNKEY
Joined Nov 12, '03
QUOTE(soltrain @ Jan 28, 2005 - 2:19 AM)
[right][snapback]239395[/snapback][/right]
the JIC Magic would probably be great coilovers if you can actually find them for are car. i havent found any at all.
FlickR
post Jan 31, 2005 - 3:39 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
QUOTE(Digndoug @ Jan 29, 2005 - 8:58 PM)
[right][snapback]239836[/snapback][/right]
their made to withstand the abuse from lowering the car becuase the stock ones don't hold up as well. and the camber can also be adjusted from under the hood.
Lo-Fi Version Time is now: May 17th, 2026 - 7:01 PM
