> Turbo Q, Help!
post Jan 21, 2005 - 9:41 PM
d3monc3lica
Joined Aug 19, '04
From Maine
Simple q, is the turbine supposed to spin freely in a turbo thats not installed, or are you not supposed to be able to turn it with your fingers???? It's outside of my car btw for anyone that didn catch that.
This post has been edited by d3monc3lica: Jan 22, 2005 - 1:42 AM
Replies (1 - 8)
post Jan 21, 2005 - 9:58 PM
Chrobis
Joined Apr 15, '03
From San Jose, CA, USA
the turbine should spin freely
although it should not wiggle, that would be called "shaft play" and means the turbo is on its way out.
post Jan 21, 2005 - 10:02 PM
d3monc3lica
Joined Aug 19, '04
From Maine
interesting......well looks to me like ive got myself a bad turbo then, because my turbo doesnt spin AT ALL, theres no shaft play, but the turbine doesnt spin its locked there....
This post has been edited by d3monc3lica: Jan 22, 2005 - 1:39 AM
post Jan 22, 2005 - 1:41 AM
d3monc3lica
Joined Aug 19, '04
From Maine
Ok i just got home from work and I was kinda hopeing that the turbo might have just been a little frozen up because its damn cold here and the package was outside for a while, now! is there anything I can do to fix this or free it up? Can i lube it up with some WD40? Or would that be a stupid mistake.....I'd just like this to work , its already been on a car and it worked on that car up until it was taken off, so it should work now right??? theres not a damn bit of shaft play either.....what are my options???
post Jan 22, 2005 - 2:20 AM
are u talking hot side or cold side? try to feel the inside of the housing to see if theres marks made by the wheel scraping it.
No you cant use WD40 lol - you'll need a rebuild.
post Jan 22, 2005 - 6:35 PM
d3monc3lica
Joined Aug 19, '04
From Maine
No Marks, both sides the shaft doesnt spin at all. frown.gif how much for a rebuild for this, i might as well just go buy a T3
post Jan 23, 2005 - 11:16 PM
d3monc3lica
Joined Aug 19, '04
From Maine
HAHA!!! They spin, they just needed a little force, i just wasnt pushing hard enough thats all, probably helped that its warmed up now that its in my room. Anyways is it supposed to be able to just turn with no problem or is some force needed to spin the blades?
post Jan 24, 2005 - 2:51 AM
forkee
Joined Nov 13, '02
From So Cal
they should turn with no problem. UNLESS you just got it rebuilt, like me. i had horrible shaft play so my mechanic made the compressor shaft seal tight. it now has NO shaft play. it does have a lil turn resistance when it just sits there, and it doesnt spin at idle, but once u give it some gas it moves nicely. biggrin.gif
post Jan 24, 2005 - 11:56 PM
d3monc3lica
Joined Aug 19, '04
From Maine
well this one has been outside of the car for a while, so i guess ill just have to wait and see, its turns but it has some resistance, but hopefully when its on the car and it gets lubed up it will fix itself.
Lo-Fi Version Time is now: August 29th, 2026 - 3:37 PM
