post Jan 23, 2005 - 11:28 PM
erics1one
Joined Aug 27, '04
From Orange County, CA
This post has been edited by erics1one: Sep 22, 2009 - 11:15 AM
post Jan 23, 2005 - 11:40 PM
spunky393
Joined Apr 22, '04
From illinois
unplug it untill you get it tuned of course
post Jan 23, 2005 - 11:46 PM
maby your stock o2 sensor went bad? this is one of those times when autometer air to fuel gauges come in handy (not to tell you ritch or lean, just to tell u the sensor is working right).
post Jan 24, 2005 - 1:54 AM
erics1one
Joined Aug 27, '04
Well I've already replaced the primary O2, but I'll pull the codes again.
Thing is...I've heard of some people making adjustments to their AFR on the fly. Wasn't sure if a few % here and there would harm anything. Obviously unplugging it would be the easy way out.
post Jan 24, 2005 - 11:01 AM
Experimenting with air fuel ratios is how you blow up your engine.
post Jan 24, 2005 - 2:45 PM
erics1one
Joined Aug 27, '04
Well I unplugged it, reset ECU, and still same problem. It'll have a weak idle, and when I push the accelerater the RPMs will drop, before beginning to rise. Sounds like a bad vac leak when accelerating, but I've checked every line 10 times. When I let off the accel. the BOV flutters and RPMs dip down to almost 0.
Gonna see if new plugs, cap, and rotor will do it. NGK wires should still be good, but I'll test em.
This post has been edited by erics1one: Jan 24, 2005 - 2:48 PM
post Jan 24, 2005 - 3:45 PM
946thGenGT
Joined Oct 4, '04
QUOTE(erics1one @ Jan 24, 2005 - 7:45 PM)
[right][snapback]237701[/snapback][/right]
Good plan - I had a very similar problem to this on my 4th Gen Celica... Replaced my plugs, plug wires, distributor cap and rotor and it ran better than ever.
post Jan 26, 2005 - 1:52 AM
erics1one
Joined Aug 27, '04
Well new plugs, rotor, and cap...and no difference. Actually died when dropping down to low rpms after a quick rev. Theres just absolutely no power. It does let out a quick "squeak" sometimes, right before the rev. Don't know if that could be anything. confused.gif
Plugs were quite black though.
Any ideas on what it could be?
This post has been edited by erics1one: Jan 26, 2005 - 1:57 AM
post Jan 26, 2005 - 8:52 AM
maikl
Joined Mar 3, '03
From cyprus
did you checke'd your ignition? i thing that you need to get your self an ecu power-fc , motec or even an e-manage and go to a dyno and tune your car the right way, to have your Plugs black propaply meens that your air fuel ratio is not good and need's tuning..... do you have any dificulty startibg your car some times?
post Jan 26, 2005 - 9:02 AM
doGGy
Joined Oct 28, '02
From Europe, Lithuania
Dyno tune it. Now you are like a blind man in a labirynt. You dont know what ya doing and its like operating angina through the but... biggrin.gif
Let the people who know they $hit do the job, or you want to blow your 5S?
<<<<<< DCw / JDMart >>>>>>>
post Jan 26, 2005 - 9:04 AM
maikl
Joined Mar 3, '03
From cyprus
or mayby your engines valve cover has cracket and loosing boost and compression...... is your boost the same as always? did you did any compression tests? mayby your pistons rings are f#*#......!
post Jan 26, 2005 - 9:41 AM
erics1one
Joined Aug 27, '04
I know I've been running rich. Its never had a problem starting.
Well I can understand the need for a dyno tune to run at maximum efficiency, but why would it all the sudden get this huge bog down after no changes at all. The exhaust sounds like I'm a beefed up truck. Its been running good for about 6 months, and since I've never seen a hint of black smoke, I didn't think I was running rich enough to harm anything.
It definitely sounds like something internal finally gave way.
Guess I'll go NA and try to get my warranty to cover a swap.
edit: Changed title from "HKS S-AFR, unplug or experiment" to "Barely stayin alive" since I'm not really asking about the AFR anymore. Even though this problem was going on before I unplugged it, I'll connect it back up, reset the ECU and see if I get anything different.
This post has been edited by erics1one: Jan 26, 2005 - 10:55 AM
post Jan 26, 2005 - 1:23 PM
Fox-N-It2
Joined Jul 24, '04
From Va
You are way to rich at idle. Lean it out a bit and go easy on the boost until you can get to someone to tune it.
post Jan 26, 2005 - 1:51 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
if u go NA ill trade u stock injectors and stock fuel pump just for ur pump?
post Jan 26, 2005 - 2:07 PM
Newbie
Joined Nov 3, '04
From Colorado
Like couple people said, you should try tuning your car.. It sounds like you are running way too rich for the car to handle or the spark plugs to burn off all that fuel that's coming in due to more air that's being pushed into the engine.. You might want to either get it tuned first, then fix the problems, or go into stock form, and fix the problem.. Either way, you'll have to tune it for more air that's coming in... Good luck.
post Jan 26, 2005 - 2:12 PM
erics1one
Joined Aug 27, '04
I know, I've said it many times before that I understand tuning my car would help it run best.
But in the condition its in right now, I highly doubt its a tuning issue. Even before when the tuning was off, it still ran like a champ, at little rich...but still ran fine.
Right now, it is no where close to running 'okay'. There is something else going on.
This post has been edited by erics1one: Jan 26, 2005 - 2:13 PM
post Jan 27, 2005 - 4:15 AM
Newbie
Joined Nov 3, '04
From Colorado
Did you check the fuel filter? Or anything like that?
post Jan 27, 2005 - 9:18 AM
what vac readings are you getting at idle? the rpms droping kind of sounds like the issues i had with boost leak.
post Jan 27, 2005 - 9:58 AM
toyotatech3
Joined Jul 30, '04
From colorado
sounds like your catalytic converter is pluged, and if it was running rich for a long time that would do it. if uyou can disconnect the exhaust before the cat and see how it runs.
post Jan 27, 2005 - 11:54 AM
erics1one
Joined Aug 27, '04
Fuel filter recently replaced. About 300 miles on new one.
Vac was at around 14psi when idleing rough. Does sound like a vac or boost leak, but I've checked all lines, and made sure all the bolts were torqued.
I have no CAT.
Last night I plugged my HKS AFR back in, and reset the ECU. It seems this has made it more 'driveable' but still seeing noticeable resistance at 1400-1900 rpms. At this point, I can see that tuning this smaller barrier might fix the problem. The complete bog down, and stalling attempts seems to be gone, but will be able to test drive her tonight.
After plugging the AFR back in, idle vac sat around 18-19psi and rpms were a lot stronger. Didn't have time to get her out on the road though.
Appreciate the input, I'll update when I get more info.
This post has been edited by erics1one: Jan 27, 2005 - 11:56 AM
Lo-Fi Version Time is now: July 9th, 2026 - 8:03 AM
