post Jan 23, 2005 - 11:28 PM
erics1one
Joined Aug 27, '04
From Orange County, CA
This post has been edited by erics1one: Sep 22, 2009 - 11:15 AM
- erics1one   ...   Jan 23, 2005 - 11:28 PM
- - spunky393   unplug it untill you get it tuned of course   Jan 23, 2005 - 11:40 PM
- - lagos   maby your stock o2 sensor went bad? this is one of...   Jan 23, 2005 - 11:46 PM
- - erics1one   Well I've already replaced the primary O2, but...   Jan 24, 2005 - 1:54 AM
- - Supersprynt   Experimenting with air fuel ratios is how you blow...   Jan 24, 2005 - 11:01 AM
- - erics1one   Well I unplugged it, reset ECU, and still same pro...   Jan 24, 2005 - 2:45 PM
|- - 946thGenGT   QUOTE(erics1one @ Jan 24, 2005 - 7:45 PM)Well...   Jan 24, 2005 - 3:45 PM
- - erics1one   Well new plugs, rotor, and cap...and no difference...   Jan 26, 2005 - 1:52 AM
- - maikl   did you checke'd your ignition? i thing that y...   Jan 26, 2005 - 8:52 AM
- - doGGy   Dyno tune it. Now you are like a blind man in a la...   Jan 26, 2005 - 9:02 AM
- - maikl   or mayby your engines valve cover has cracket and ...   Jan 26, 2005 - 9:04 AM
- - erics1one   I know I've been running rich. Its never had ...   Jan 26, 2005 - 9:41 AM
- - Fox-N-It2   You are way to rich at idle. Lean it out a bit an...   Jan 26, 2005 - 1:23 PM
- - x_itchy_b_x   if u go NA ill trade u stock injectors and stock f...   Jan 26, 2005 - 1:51 PM
- - Newbie   Like couple people said, you should try tuning you...   Jan 26, 2005 - 2:07 PM
- - erics1one   I know, I've said it many times before that I ...   Jan 26, 2005 - 2:12 PM
- - Newbie   Did you check the fuel filter? Or anything like th...   Jan 27, 2005 - 4:15 AM
- - lagos   what vac readings are you getting at idle? the rp...   Jan 27, 2005 - 9:18 AM
- - toyotatech3   sounds like your catalytic converter is pluged, an...   Jan 27, 2005 - 9:58 AM
- - erics1one   Fuel filter recently replaced. About 300 miles on...   Jan 27, 2005 - 11:54 AM
- - boosted_K2   what is your boost like? does it feel any differen...   Jan 27, 2005 - 9:46 PM
- - lagos   14 vac seems really low, at least it would be for ...   Jan 27, 2005 - 10:53 PM
- - erics1one   Should be between ~18-21. As I said though, it wa...   Jan 28, 2005 - 1:25 AM
- - presure2   eric, id do a compression test, just to be on the ...   Jan 28, 2005 - 9:56 AM
- - erics1one   Planning to compression test it soon. Did a while...   Jan 28, 2005 - 10:48 AM
- - erics1one   Doing this again, with the S-AFR plugged in. It f...   Feb 18, 2005 - 11:30 AM
Lo-Fi Version Time is now: July 9th, 2026 - 9:24 AM
