Jan 27, 2005 - 12:32 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
Well there is a lot of good info on here and I just want it in one spot i know kwanza and others have talked about it quite a bit so if you could add to this list that would be great.
Some people with good knowledge DMC, FROTOU, KWANZA, DOGGY, EDO, FALLENHERO, 2zzge rods length 5.429 (wiseco) 7afe rods length 5.217 ( Pauter) difference .212 a lot of info here about 4age http://www.needfulthings.net/ostc/4age.htm this is an idea have them make a connector 7afe to 4age with MAP http://www.autosportwiring.com/pages/1/index.htm 7age info http://www.corollaperformance.com/Mods/Eng...GE.html#rayhall http://te51levin.superjamie.net/7age/ FROTOU the man with the 7agte http://www.6gc.net/forums/index.php?showtopic=8586&hl= good place to ask questions http://www.club4ag.com/ This post has been edited by nik: Jan 28, 2005 - 12:58 PM -------------------- yea your 3sgte is cool but ill stick to my 7agte
nik 7agte HELP Jan 27, 2005 - 12:32 PM
FallenHero Here is my contribution.
Fallen's info (for... Jan 28, 2005 - 12:10 AM
nik well im leaving the 7afte and going into 7agte mod... Jan 28, 2005 - 12:57 PM
thedevilmaycrie you will need the igniton system from the geo... i... Jan 28, 2005 - 1:50 PM
nik QUOTE(thedevilmaycrie @ Jan 28, 2005 - 11:50 ... Jan 28, 2005 - 2:51 PM
FallenHero well, it wasn't obd2 becaus that system was ad... Jan 28, 2005 - 5:03 PM
nik QUOTE(FallenHero @ Jan 28, 2005 - 3:03 PM)wel... Jan 28, 2005 - 5:43 PM
thedevilmaycrie you HAVE to use the 4age harness and ecu.... and ... Jan 28, 2005 - 5:54 PM
nik QUOTE(thedevilmaycrie @ Jan 28, 2005 - 3:54 P... Jan 28, 2005 - 6:10 PM
thedevilmaycrie i beleive 4agze harness and sensors are needed ...... Jan 28, 2005 - 6:24 PM
nik QUOTE(thedevilmaycrie @ Jan 28, 2005 - 4:24 P... Jan 28, 2005 - 6:28 PM
thedevilmaycrie ummm ad ask fontu (the featured ride ..) he's ... Jan 28, 2005 - 6:30 PM
frotou Yeah, I'm selling my wiring harness and ecu be... Jan 28, 2005 - 7:23 PM
Kwanza26 Nik... there is no real advantage in using the MAP... Jan 28, 2005 - 8:54 PM
nik what do you recommend for a MAP sensor? Jan 31, 2005 - 10:06 AM
nik all 20v are tvis right? can i do a black top ITB w... Jan 31, 2005 - 1:31 PM
FallenHero 20v were not TVIS they were vvt. No 4ag TVIS afte... Feb 1, 2005 - 10:44 AM
nik QUOTE(FallenHero @ Feb 1, 2005 - 8:44 AM)20v ... Feb 1, 2005 - 11:12 AM
edo17982 like every engine man....get CR ratio to 9:1 or ev... Feb 1, 2005 - 12:58 PM
nik QUOTE(edo17982 @ Feb 1, 2005 - 10:58 AM)like ... Feb 1, 2005 - 1:35 PM
Kwanza26 QUOTE(nik @ Feb 1, 2005 - 6:35 PM)but will i ... Feb 1, 2005 - 4:39 PM
Mr2swift Ok here is what I think, and you can use my pesona... Feb 1, 2005 - 2:58 PM
nik was the gze head direct bolt on? And i'm not g... Feb 1, 2005 - 4:27 PM
Mr2swift Yes the Gze head is a direct bolt on like the 4ag.... Feb 1, 2005 - 4:34 PM
frotou After 12-14 psi the 4agze ecu read to much air and... Feb 1, 2005 - 5:04 PM
edo17982 QUOTE(frotou @ Feb 2, 2005 - 12:04 AM)After 1... Feb 1, 2005 - 5:22 PM
nik QUOTE(frotou @ Feb 1, 2005 - 3:04 PM)After 12... Feb 1, 2005 - 5:26 PM
frotou The most simple solution for you nik ; big port an... Feb 1, 2005 - 10:39 PM
Mr2swift QUOTE(frotou @ Feb 2, 2005 - 3:39 AM)The most... Feb 2, 2005 - 2:49 AM
nik QUOTE(frotou @ Jan 28, 2005 - 5:23 PM)
The ot... Feb 2, 2005 - 1:35 PM
frotou The jdm gze 90 and before is not dli but afm and a... Feb 2, 2005 - 4:51 PM
nik QUOTE(frotou @ Feb 2, 2005 - 2:51 PM)The jdm ... Feb 2, 2005 - 5:32 PM
Mr2swift You can not retard the timing on a map based gze w... Feb 2, 2005 - 7:07 PM
nik QUOTE(Mr2swift @ Feb 2, 2005 - 5:07 PM)You ca... Feb 3, 2005 - 10:09 AM
frotou If you talk about my wiring on ebay, yes I include... Feb 3, 2005 - 4:52 PM
nik QUOTE(frotou @ Feb 3, 2005 - 2:52 PM)If you t... Feb 3, 2005 - 5:15 PM
nik well it started i bought the head 4agze big port n... Feb 14, 2005 - 11:49 AM
nik does topshelfracing still do wiring?
AE92 to 6th g... Feb 14, 2005 - 12:29 PM
FallenHero http://www.topshelfracing.com/
Home page says no,... Feb 14, 2005 - 4:57 PM
nik i think i might have to go stand alone. Feb 14, 2005 - 5:07 PM
thedevilmaycrie im gonna talk to my friend and see if i can get hi... Feb 14, 2005 - 5:32 PM
nik QUOTE(thedevilmaycrie @ Feb 14, 2005 - 3:32 P... Feb 14, 2005 - 5:40 PM![]() ![]() |
| Lo-Fi Version | Time is now: July 31st, 2026 - 11:11 AM |
