> Places to pull 4 gauge amp wire through?
post Jan 27, 2005 - 5:12 PM
slipgun
Joined Jun 2, '03
From Annandale VA
Sorry guys I know this was covered and ive been scanning and I cant find it, I cant find the hole to pull the wire into the cabin I know there was a picture once. How did you all pull your wire? I need one into my trunk for my subs and one into the cabin for my mbquart components, any ideas? Pictures are awesome if you have one smile.gif
post Jan 27, 2005 - 5:23 PM
Scarrell
Joined Nov 8, '04
From Carmi, Illinois
well if you cant find the hole, you can drill a hole but make sure there isnt any electrical stuff in the way and use a gromet. and what do you mean for your components? i hope not for speaker wire, you dont need speaker wire that big for components...
i want a stereo so loud, it blows womens clothes off.
TrickedOutS2000: I just opened a box that arrived on my doorstep cuz i thought it was my H.U.
TrickedOutS2000: it was a vibrator my dad bought
scarr3ll: WHAT THE ****?!?11
TrickedOutS2000: yeh
TrickedOutS2000: for my mom im guessing
TrickedOutS2000: but yeah
TrickedOutS2000: eww
TrickedOutS2000: so
TrickedOutS2000: ****ing
TrickedOutS2000: wrong
My Cardomain Page.
Car Audio Central
msn: jared_s_c@hotmail.com
aim: Scarr3ll
post Jan 27, 2005 - 5:41 PM
slipgun
Joined Jun 2, '03
From Annandale VA
Its gona be running 320 watt rms for all my components, I had a discount and easy access to a 4 gauge wireing kit soo I figured why not, its rated for 600 rms your right.
I actualy just found a little black tube that seems to run inside looks like i need to take appart my passenger side dash to really see though, will only fit one 4 gauge wire though.
This post has been edited by slipgun: Jan 27, 2005 - 5:41 PM
post Jan 27, 2005 - 6:11 PM
Scarrell
Joined Nov 8, '04
hmm... thats the bad part about running bigger gauge wire... keep on truckin thhough
TrickedOutS2000: so
My Cardomain Page.
Car Audio Central
aim: Scarr3ll
post Jan 27, 2005 - 7:11 PM
I drilled a hole in my firewall on the driver's side and used a rubber grommet and it works perfectly. smile.gif
post Jan 28, 2005 - 6:24 AM
slipgun
Joined Jun 2, '03
From Annandale VA
Which end did you drill the hole on to make sure you dint cut any elctronics? Did you take appart your driver side dash climb under and drill?
Also on another note.... how did you put a positive 4 gauge wire to connect to the battery. Should I just recreate the connector with all the wires connecting to the battery or what?
This post has been edited by slipgun: Jan 28, 2005 - 6:35 AM
post Jan 28, 2005 - 1:03 PM
prpnum1
Joined Aug 7, '04
From US
I have like 3 holes in my firewall just find a good spot and drill from under the hood or wherever is easiest for you. you dont have to take apart the dash.
post Jan 28, 2005 - 2:06 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
if you dont wanna drill a hole in your firewall.... your rubber boot that your steering colunm runs though, i cut a small slit in that and ran my old amp power wire your it... worked perfect for me...
-DMC
post Jan 28, 2005 - 3:39 PM
Seth6Gen
Joined Sep 22, '02
From Mammoth CA
DONT drill a hole in your firewall thats stupid. there is a rubber thingy(technical term) on the top left of your engine bay, poke a hole in that and run it through there, i taped it up afterwords just so no water or anything would go though.
dident think that would work heres a pic on image station, or i can send it to you email if u want
http://www.imagestation.com/album/pictures...l?id=2131492254
This post has been edited by Seth6Gen: Jan 28, 2005 - 3:42 PM
post Jan 28, 2005 - 5:38 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
QUOTE(Seth6Gen @ Jan 28, 2005 - 12:39 PM)
[right][snapback]239561[/snapback][/right]
that would be great but that means that you have to run it across your engine bay to meet your battery... and if your like me i had my amp mounted on my back seat... thats a long a$$ wire...
-DMC
post Jan 28, 2005 - 7:56 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
QUOTE(thedevilmaycrie @ Jan 28, 2005 - 10:38 PM)
-DMC
[right][snapback]239595[/snapback][/right]
Thats what i did and it did need long asss wire, but it was easy, i couldnt find an bits or good spots to drill a hole.
post Jan 28, 2005 - 10:10 PM
slipgun
Joined Jun 2, '03
From Annandale VA
And that my friends.... was the picture I was tryna remember!! Thanks man! I have long ass wires so looks great!
post Jan 29, 2005 - 11:57 AM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
i just drilled a hole where i'll need it in the end anyways...
when/if i convert over, iunno where i'll run it...but i'll search this post up most likely tongue.gif
post Jan 29, 2005 - 1:58 PM
TRD6GC
Joined Nov 17, '03
OK i have ZERO gauge and i put it through my firewall, on the driver side, with no drilling.....theres a thick wire with a rubber like cover on it, it goes through the firewall wheres there a rubber, um like gromet or bushing you would call it, you can push that to the side and get the wire through it. Then the rubbing bushing closes back over the wire and seals back up, worked for me!
post Jan 29, 2005 - 4:33 PM
DamDirtyApes
Joined Apr 22, '04
From Rhode Island
my firewall had a pre drilled hole in it....
post Jan 29, 2005 - 10:42 PM
Seth6Gen
Joined Sep 22, '02
From Mammoth CA
i bought a kit, and i had mad wire left over too. its really not that long if you just run it back on the drivers right side. its only like an extra 2 feet. not that bad.
Lo-Fi Version Time is now: September 14th, 2026 - 3:04 AM
