Jan 28, 2005 - 12:05 AM
Enthusiast ![]() ![]() ![]() Joined Aug 18, '04 From NJ Currently Offline Reputation: 1 (100%) |
i know people talk about this all the time but i was just wondering if anybody changed the color of their clock from stock bright green to red. i kinda dont think its possible but if anybody has done it can you fill me in. (i read that some ppls stock color are white. lucky bums!)
o yea lost one of those rubber pieces that touch the circuit board so if anybody wants to give me one or send me a white clock (i'll pay 4 it) i would appreciate it! This post has been edited by juBz86: Jan 28, 2005 - 12:08 AM |
Jan 28, 2005 - 12:16 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 8, '04 From LA Currently Offline Reputation: 0 (0%) |
yeah. it's not possible. no one can ever do it! NEVER!!!!
flash makes it look like crap
Jan 28, 2005 - 12:17 AM
how did you do it shid? what did you use?
Jan 28, 2005 - 12:20 AM
Woops, I totally forgot to answer that part of the question.
I used folder tabs- the kind you find in file cabinets. The kind for binders I found were too pinkish and too transparent. I've been looking into jacking some color gels from work tho, and getting a better color with less light depreciation Basically you just open up your clock (four very tiny screws) remove the green plastic piece, and replace it with a color gel of your choice. Remember tho, red is the underachiever of the visual spectrum. |
Jan 28, 2005 - 12:22 AM
i dont have a green plastic piece its more like an amber color. it tones down the super bright green that the clock emits.
Jan 28, 2005 - 12:24 AM
yeah, I guess mine was kind amber. Anyway. replace that.
Jan 28, 2005 - 12:25 AM
ok thanx i'll try that after school 2morrow
Jan 28, 2005 - 2:40 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 16, '03 From Bay area Currently Offline Reputation: 0 (0%) |
if you remove the green plastic would the clock glow white?
Jan 28, 2005 - 2:50 AM
![]() Enthusiast ![]() Joined Oct 29, '03 From Gosport, Hampshire, UK Currently Offline Reputation: 0 (0%) |
bear in mind, the amber piece will probably break as it comes out. No biggy though, as it's a horrible-colour thing anyway. hehe.
I used the stage-lighting gel stuff for mine (blue), it's one of the easiest things to do.... a cheap and cheerful job -------------------- |
Jan 28, 2005 - 6:26 AM
Enthusiast ![]() ![]() ![]() Joined Nov 14, '04 Currently Offline Reputation: 0 (0%) |
The only problem with this is not all the clocks have the same color my 95st's clock color is teal without the amber lense but a few people on here said that there's was white.
Jan 28, 2005 - 7:39 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
Where do you get stage lighting gel from?
Jan 28, 2005 - 11:49 AM
hanyo- i'm not sure but i think i read amyjo's clock was white w/out the amber thing. but mine is bright green.
i'm gonna check micheals art supply store or like walmart or somewhere. i know ebay has some. ebay i'll post again later when i get home. |
Jan 28, 2005 - 10:36 PM
ok i finally got it! i got a pack of hanging folder tabs from walmart. its a pack of 24 and i used one. who wants one? there are red blue and yellow. u could use them for the turn signals to change them from the green to watever.
anyway back to the subject. i only used one red tab. and i ended up using a glue gun to glue it down and left the amber lens out of it. anyway it looks decent for now. not the best but it looks good enough. |
Jan 29, 2005 - 3:57 AM
yeah I kept my amber lens out too. I ended up using two layers of the red tint however
Jul 12, 2006 - 6:47 PM
Enthusiast ![]() ![]() Joined May 25, '06 From South Carolina Currently Offline Reputation: 3 (100%) |
do you need to upgrade the light to make it nice? or is that the stock light in your photo shid?
Jul 13, 2006 - 10:35 AM
![]() Enthusiast ![]() ![]() ![]() Joined Mar 28, '06 From Brooklyn, New York Currently Offline Reputation: 1 (100%) |
QUOTE(Griff @ Jul 12, 2006 - 7:47 PM) [snapback]455303[/snapback] do you need to upgrade the light to make it nice? or is that the stock light in your photo shid? stock lights are good enough, just take a folder tab and place it there |
Jul 13, 2006 - 4:00 PM
![]() Enthusiast ![]() ![]() Joined Feb 3, '05 From USA/Virginia Currently Offline Reputation: 2 (100%) |
i got my lighting gels from here
http://axemusic.com/prodType.asp?PT_ID=211...strPageHistory= and an 1/8 inch piece of plexi glass from home-depot. broke the original amber lens out. cut off a small rectangle of plexiglass, then used a bastard file to make it fit perfect. wasn't held in by clips or anything, just sandwiched in there by the clock housing. the plexi glass doesn't curve like the original amber lens. but the final product looks great. |
Jul 13, 2006 - 4:04 PM
Enthusiast ![]() ![]() ![]() Joined Mar 29, '06 From Regina, SK, Canada Currently Offline Reputation: 38 (100%) |
So after reading this topic yesturday I went home and changed my clock color. However I was disappointed. After taking that amber lens off the clock color was still basically the same, the ugly green color. So then I inserted my blue folder tab and it really didn't do anything, my clock is still quite green looking.
Should I be using another layer of blue folder tab or do I need something better than a folder tab to get the blue color? Is it even possible to get the color to be blue since the bulb is basically green? For all of you who have blue clocks, what did you do? Change bulb or just use a blue cover? Zimluura - Did you just use those gels from the link you posted? Was your bulb white or green? Also what did you do with the light ring around the key, did you use a gel in there or did you actually change bulb to blue? Right now I have it white because I took the green cover off the bulb...hmm light bulb came on while typing, is there one of those covers on the bulb in the clock? This post has been edited by WALKER: Jul 13, 2006 - 4:08 PM -------------------- |
Jul 13, 2006 - 4:42 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Dec 9, '05 From Long Beach Currently Offline Reputation: 1 (100%) |
mix the colors! woohoo
put a green tab and a red tab to make white? am i right? -------------------- Is this good enuff 4 ya? :D
Jul 13, 2006 - 10:36 PM
I don't really think that would work. I guess I can try it. I don't really think there is any possible way to make white since it is the absence of color. Also in order to make blue it is impossible in my mind because it is a primary color...that is why I am confused as to how it was done.
I looked at my clock again and the clock display is the ugly green, don't see anyway to change that. -------------------- |
| Lo-Fi Version | Time is now: September 23rd, 2026 - 1:51 AM |
