Jan 31, 2005 - 2:28 AM
Enthusiast ![]() ![]() ![]() Joined Feb 27, '04 From Illinois Currently Offline Reputation: 1 (100%) |
I've searched til my head hurts and I can't find the answer to my question...
will the axles from an ST185 All Trac work in an MR2T transmission with LSD? -------------------- ![]() |
Jan 31, 2005 - 9:45 AM
Yota, I do not know about the alltrac axels. Here is the thread where Ray (Kuya1284) talks about the axels you need and the fact that he used 88-91 camry V6 outter half-shafts:
MR2T Transmission Conversion In sum: The inner half-shafts need to be MR2T axles (LSD or non-LSD type, depending if you decide to install the LSD)... With my application, I'm using 88-91 V6 Camry outter half-shafts to make this work... you cannot use the full MR2T axles because 1. They're too short 2. The outter shaft will not connect to your hub (as I understand it) You should be able to find these on car-part.com for less than $100-$200. Hope it helps. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Jan 31, 2005 - 9:50 AM
From what I hear ( dont know 100% since mines not installed) the Alltrac outter 1/2s will work same as the Camry V6 1/2s.
Jan 31, 2005 - 11:33 PM
J-
Thanks man. That clarifies my confusion. -------------------- ![]() |
| Lo-Fi Version | Time is now: September 2nd, 2026 - 8:41 PM |
