Feb 1, 2005 - 1:27 PM
Enthusiast ![]() Joined Dec 10, '04 From Ottawa Currently Offline Reputation: 0 (0%) |
Hey..I am just wondering if anyone else is having the same problem as what Im having.
I have a 94 celica gts and it was totally fine when it was stock. but ever since I installed the Ground Control Coilovers, it's making noise. Noise comes from the upper strut mount which the plastic strut mount is rubbing the steel frame. I went to the dealer to get it fixed, they can't fix it(and took my money) and went to some different aftermarket shops..noone can fix my problem. someone told me if I change my coilovers to just lowering spiring it may go away. Anyone know how to fix this problem? |
3sgtegts Problem with suspension Feb 1, 2005 - 1:27 PM
BLINKYxMUNKEY is it a popping noice whenever you turn? Feb 1, 2005 - 2:03 PM
Digndoug Theres just a mount peace u need to buy. Feb 1, 2005 - 5:30 PM
playr158 evilspeed.com sells the bearings that you need i d... Feb 1, 2005 - 6:18 PM
3sgtegts It's a Plastic and Steel Rubbing sound.
it may... Feb 1, 2005 - 6:43 PM
Junior your top mounts may be worn out. Check out the TR... Feb 2, 2005 - 7:08 PM
3sgtegts I've already changed the Strut mounts on both ... Feb 3, 2005 - 1:32 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 2nd, 2026 - 9:23 AM |
