Feb 1, 2005 - 10:10 PM
im looking into getting new rims and tires and im as little torn on what i should get. my goals are to get an 8in wide rim with a 35 offset, and get the best ride quality out of the tires i put on them.
my original plan was to get a set 17x8s with 225-45-17 tires. during my shopping around, i noticed that the selection for 17x8s was low and that most of the rims i find cost more then i want to spend. i started looking around at 18x8s. they seem to look almost perfect for our cars. i figure i can fit a 225-40-18 tire and still get good ride quality. my current setup is 17x7s with 205-40-17 tires. im kind of sick of the less then stock ride quailty evertime i hit a small bump in the road. so basically my question is.... how much better would the car ride with 225-45-17 vs 225-40-18s? would i have to worry about rubbing issues if i get those tires on 18s? anyone have that same setup and want to give their opinions? This post has been edited by lagos: Feb 1, 2005 - 10:10 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
lagos 17x8s or 18x8s Feb 1, 2005 - 10:10 PM
jgreening The biggest difference in ride quality is going to... Feb 1, 2005 - 10:18 PM
Mr_E I'm switching to 18x8s running 225x40's.
... Feb 2, 2005 - 4:05 AM
Supersprynt I have 18x7.5's with 35mm sidewall - I dont re... Feb 2, 2005 - 9:33 AM
Bigmeanbulldog55 With 18's you'd have to worry a lot about ... Feb 2, 2005 - 10:16 AM
Mr_E QUOTE(Bigmeanbulldog55 @ Feb 2, 2005 - 10:16 ... Feb 2, 2005 - 10:18 AM
Dacoolguychris in my opinion if you're going for 17's or ... Feb 3, 2005 - 1:33 AM
Supersprynt My rims about 21lbs a piece. Feb 3, 2005 - 8:16 AM
Jdog1385 i have 18's with a 35mm sidewall. not the wor... Feb 4, 2005 - 11:01 PM
Mr_E Ah - well that's that idea scuppered then........ Feb 5, 2005 - 9:45 AM
Newbie I wouldn't recommend anything below 45.. Other... Feb 6, 2005 - 9:19 AM
bufferdan Just put some 225/45's on your 17in wheels you... Feb 8, 2005 - 9:50 AM
bufferdan If your still lowered with eibach sportlines i thi... Feb 8, 2005 - 9:53 AM
lagos QUOTE(bufferdan @ Feb 8, 2005 - 9:53 AM)If yo... Feb 8, 2005 - 10:44 AM
Jdog1385 i put the prokit in my car, couldnt even tell the ... Feb 8, 2005 - 11:36 AM
Drocay sorry kinda off topic, but will 235x45x18 fit. Feb 8, 2005 - 6:41 PM
bufferdan 235/45/18 would be BIG...i doubt it would.... 23... Feb 8, 2005 - 11:58 PM
Mr_E I think I've decided.
Going 18x8 225/40R18 Feb 9, 2005 - 5:25 AM
FORGMANN great choice ..
fensport told me best size fo... Feb 9, 2005 - 7:20 AM
Hanyo what is the tallest tire wall you can have with 17... Feb 10, 2005 - 3:43 AM
Mr_E To keep the rolling radius on mine, 235/40R17... Feb 10, 2005 - 5:14 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 2nd, 2026 - 9:53 AM |
