> 17x8s or 18x8s, whats best for ride quality
post Feb 1, 2005 - 10:10 PM
im looking into getting new rims and tires and im as little torn on what i should get. my goals are to get an 8in wide rim with a 35 offset, and get the best ride quality out of the tires i put on them.
my original plan was to get a set 17x8s with 225-45-17 tires. during my shopping around, i noticed that the selection for 17x8s was low and that most of the rims i find cost more then i want to spend.
i started looking around at 18x8s. they seem to look almost perfect for our cars. i figure i can fit a 225-40-18 tire and still get good ride quality.
my current setup is 17x7s with 205-40-17 tires. im kind of sick of the less then stock ride quailty evertime i hit a small bump in the road.
so basically my question is.... how much better would the car ride with 225-45-17 vs 225-40-18s? would i have to worry about rubbing issues if i get those tires on 18s? anyone have that same setup and want to give their opinions?
This post has been edited by lagos: Feb 1, 2005 - 10:10 PM
- lagos   17x8s or 18x8s   Feb 1, 2005 - 10:10 PM
- - jgreening   The biggest difference in ride quality is going to...   Feb 1, 2005 - 10:18 PM
- - Mr_E   I'm switching to 18x8s running 225x40's. ...   Feb 2, 2005 - 4:05 AM
- - Supersprynt   I have 18x7.5's with 35mm sidewall - I dont re...   Feb 2, 2005 - 9:33 AM
- - Bigmeanbulldog55   With 18's you'd have to worry a lot about ...   Feb 2, 2005 - 10:16 AM
|- - Mr_E   QUOTE(Bigmeanbulldog55 @ Feb 2, 2005 - 10:16 ...   Feb 2, 2005 - 10:18 AM
- - Dacoolguychris   in my opinion if you're going for 17's or ...   Feb 3, 2005 - 1:33 AM
- - Supersprynt   My rims about 21lbs a piece.   Feb 3, 2005 - 8:16 AM
- - Jdog1385   i have 18's with a 35mm sidewall. not the wor...   Feb 4, 2005 - 11:01 PM
- - Mr_E   Ah - well that's that idea scuppered then........   Feb 5, 2005 - 9:45 AM
- - Newbie   I wouldn't recommend anything below 45.. Other...   Feb 6, 2005 - 9:19 AM
- - bufferdan   Just put some 225/45's on your 17in wheels you...   Feb 8, 2005 - 9:50 AM
- - bufferdan   If your still lowered with eibach sportlines i thi...   Feb 8, 2005 - 9:53 AM
- - lagos   QUOTE(bufferdan @ Feb 8, 2005 - 9:53 AM)If yo...   Feb 8, 2005 - 10:44 AM
- - Jdog1385   i put the prokit in my car, couldnt even tell the ...   Feb 8, 2005 - 11:36 AM
- - Drocay   sorry kinda off topic, but will 235x45x18 fit.   Feb 8, 2005 - 6:41 PM
- - bufferdan   235/45/18 would be BIG...i doubt it would.... 23...   Feb 8, 2005 - 11:58 PM
- - Mr_E   I think I've decided. Going 18x8 225/40R18   Feb 9, 2005 - 5:25 AM
- - FORGMANN   great choice .. fensport told me best size fo...   Feb 9, 2005 - 7:20 AM
- - Hanyo   what is the tallest tire wall you can have with 17...   Feb 10, 2005 - 3:43 AM
- - Mr_E   To keep the rolling radius on mine, 235/40R17...   Feb 10, 2005 - 5:14 AM
Lo-Fi Version Time is now: August 9th, 2026 - 3:07 PM
