Feb 10, 2005 - 5:59 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 16, '03 From Bay area Currently Offline Reputation: 0 (0%) |
I know this has been discuss several times, on what is the best suspension.
Well what is the best suspension for best ride quality. So for my idea of the best ride is: 17 in rims with 45 tire wall. tanable springs. and kyb struts. Anyone else have anything to add? comments? what is the best ride quality coil-overs? |
Feb 10, 2005 - 8:25 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 16, '04 From UK Currently Offline Reputation: 0 (0%) |
Ride quality?
A car that masses several tons, on soft springs and soggy dampers. 13" wheels with the biggest sidewalls you can find. You won't feel a thing, even when it understeers off the road into a field. -------------------- JDM ST205
Blitz Spec NUR Exhaust, somewhere over $1000 Needing another one 18000 miles later, bloody annoying. |
Feb 10, 2005 - 2:20 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
QUOTE(Mr_E @ Feb 10, 2005 - 1:25 PM) Ride quality? A car that masses several tons, on soft springs and soggy dampers. 13" wheels with the biggest sidewalls you can find. You won't feel a thing, even when it understeers off the road into a field. [right][snapback]244303[/snapback][/right] kyb struts nahhh that ain't quality. go for konis or throw in like 300 more bucks and you get get the tein ss coilovers. now that is a nice setup. my tax refund is going for tein ss and the cusco pillow ball mounts. This post has been edited by rjbibeau: Feb 10, 2005 - 2:20 PM -------------------- ![]() |
Feb 10, 2005 - 4:55 PM
the thing about tein ss are they are more sports orentated springs with increase spring rate.. The tanable springs have close to stock spring rate so the ride quality should not be too bad considering you are lowering the car and installing bigger rims..
Feb 10, 2005 - 5:51 PM
If by "best ride quality" you mean "least punishing", your answer is stock.
Feb 10, 2005 - 6:09 PM
or even better..
get 13 inch rims and put some cynder blocks in the front and rear of the car to weight it down. comon guys.. obviously i'm asking about what is the best ride quality for a lowered car. And by lowering i dont mean by adding weights to it. |
Feb 11, 2005 - 11:16 AM
well u asked a question that will ever u an answer that u will never be 100 percent happy with... u want a smooth right with ur 17's i woulld say go with some air bags .. that way u can have the nice smooth right like a caddie ... u might also want to try moving up to 50 side wall ... they tires are the one thing that will give u that smooth feel .. u can get any spring set up but if u don't have enuff air to cushion better the tread and the rim its going to be rough ..
Feb 11, 2005 - 12:18 PM
QUOTE Well what is the best suspension for best ride quality. QUOTE comon guys.. obviously i'm asking about what is the best ride quality for a lowered car. I don't find the your implied reasoning all that obvious. Despite the common perception that we have too much wheel gap, some people may be willing to live with it in order to avoid the slightest jarring effects of a performance suspension. Also, its a poorly phrased question because we don't know what you mean by "best ride quality". Best handling? Best comfort? Least bounciness? Least wheel spin in a higher powered car? Its simply not clear. I assumed you meant "least jarring". If you mean "least jarring" in a lowered car, I would stay away from eibach, trd and h & r as they are performance oriented springs. Disclaimer: I have never ridden in a car with eibach sportlines or h & r. My car has TRD springs and I have ridden in a mustang with the prokit. Best regards, Jay -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Feb 11, 2005 - 9:28 PM
exact type of answer i was looking for.
As you noticed i did not mention anything about performance. I dont believe there is an manufacture out there can makes aftermarket parts to improve on the stock comfort level. I thought air bag suspensions are bouncy? Anyone know more about this? And would 50 tire side wall even fit on a celica with 17s? |
Feb 11, 2005 - 9:41 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 22, '03 Currently Offline Reputation: 0 (0%) |
I had air suspension on my Lincoln. Nothing but smoothness. No rebound at all, that was stock suspension though.
Feb 11, 2005 - 10:47 PM
im looking for good ride quality too. im going to try upgrading to 225-45-17 tires. if that dont help, i might change the shocks and go with a eibach Prokit.
Feb 11, 2005 - 10:52 PM
I am not sure but I think the prokit would be the stiffest shocks you can get for our car. They have been characterized as the "ultimate" autocross springs by other well know members of this board. (i.e. spedtoe). You may want to hit him or conetrouble up to ask for sure.
Feb 12, 2005 - 6:15 AM
but are stiff shocks a thing you want in a suspension built around comfort?
I would think soft springs and new shocks would be the way to go. |
Feb 12, 2005 - 6:21 PM
shock selection is the single biggest factor in ride "stiffness" or the jarring / cushy feeling. There is a ton of difference between stock / KYB shocks and the koni's.
Feb 12, 2005 - 9:16 PM
QUOTE(jgreening @ Feb 12, 2005 - 4:21 PM) shock selection is the single biggest factor in ride "stiffness" or the jarring / cushy feeling. There is a ton of difference between stock / KYB shocks and the koni's. [right][snapback]245316[/snapback][/right] And the difference is? |
| Lo-Fi Version | Time is now: May 25th, 2026 - 4:55 PM |
