Feb 13, 2005 - 3:20 PM
Enthusiast Joined Apr 7, '04 From Pa Currently Offline Reputation: 0 (0%) |
I have a 94 st i am swapping the stock engine for a 3s-gte. i want to put a haltech e6k in to manage the engine. does haltech make a certain wire harness that will work with all my plugs on my engine or do i have to modify?
Feb 13, 2005 - 3:30 PM
You might want to pose your question in the engine forum. Here is a start to your answer but I am not an expert on stand alones. First, you will have to do the 7afe to 3sgte wiring swap. Then, some standalones are plug and play. Two that I know of are the AEM and the Hydra Nemesis. I do not know about the Haltech. Also, do not rely on my opinion alone on this.
Feb 13, 2005 - 3:40 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 29, '02 From ny to philly Currently Offline Reputation: 0 (0%) |
topic moved - gd
Feb 13, 2005 - 4:48 PM
even if it werent plug and play
wiring in any stand alone is easy. -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
Feb 14, 2005 - 8:43 AM
Enthusiast ![]() ![]() Joined Apr 7, '04 From Toronto Currently Offline Reputation: 3 (100%) |
you have to wire your stand alone like you were wiring your 3sgte
Feb 14, 2005 - 12:28 PM
QUOTE(ZoomZoom @ Feb 14, 2005 - 5:43 AM) you have to wire your stand alone like you were wiring your 3sgte [right][snapback]245785[/snapback][/right] wrong. -------------------- 1994 Celica GT4 WRC Edition
Feb 14, 2005 - 1:07 PM
whats wrong about that.
is your base on your experience??? |
Feb 14, 2005 - 1:10 PM
sorry, let me reprase the question.
do you have a first time experience on Haltech wiring to a 3sgte celica swap? |
Feb 14, 2005 - 6:41 PM
i have personal experience wiring a stand alone setup
its easy, you start out with all new wires. there is not hunting for the right wires in a bundle of like 100+ wires, then extending it all a couple feet. with the stand alone, you install the new sensors on the engine, then run wires from them to the stand alone. the one i did had a MAP, TPS, IAT, CHT, injectors, coilpack control wires, Hall sensor, Knock sensor. and most stand alones have pretty much the same sensor setup, sometimes they have a few more things like WBO2. its the tuning that gets complicated. This post has been edited by 97sccelica: Feb 14, 2005 - 6:42 PM -------------------- 1994 Celica GT4 WRC Edition
| Lo-Fi Version | Time is now: July 29th, 2026 - 3:56 PM |
