> brembo rotors, quick question
post Feb 13, 2005 - 4:15 PM
slim75
Joined Apr 28, '04
From utah
I was just wondering will these fit my 96 st coupe.
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...&category=33564
post Feb 13, 2005 - 10:28 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
I hear these are just for show and nothing more. These will not improve braking at all.
post Feb 13, 2005 - 10:33 PM
Redline_Racer
Joined Oct 13, '03
From Dandridge, Tennessee
are those larger than the stock GT rotors? they look to be the same size?
-Brandon
post Feb 14, 2005 - 6:16 PM
if they are brembo they are fake crossdrilled
people buy them the use a drill and drill holes in them
extremly unsafe
post Feb 14, 2005 - 7:05 PM
BLINKYxMUNKEY
Joined Nov 12, '03
From Crestview, Florida
i hear www.irotors.com carry a nice set of cross drilled rotors.
FlickR
post Feb 14, 2005 - 7:13 PM
RedSunCelica
From San Diego CA
buying cross drilled or slotted rotors will not help you stop faster it eliminates break fade.
post Feb 14, 2005 - 8:26 PM
i stop abuot 10 feet or more? beter
post Feb 14, 2005 - 9:17 PM
slipgun
Joined Jun 2, '03
From Annandale VA
They cant increase your stopping ability, less surface area for friction, they just keep the breaks from over heating so in hard driving situations its better.
post Feb 15, 2005 - 1:48 PM
bonzaisushi
Joined Oct 3, '02
From bonzaisushi@hotmail.com
i bout some cross drilled brembos, that were heat soaks and chamferd from a reliable compant, with axiss metal master break pads. it feels pretty good but cross drilling doesnt effect any thing just looks nice
post Feb 15, 2005 - 4:49 PM
it depends if it is designed right
the goal is to IMPROVE braking
when a normal rotor is heated during braking
it creates gasses that prevent the brake bad from addiqitly contacting the rotor
kinda like if you take the same polarity magnets and try to push them together they push against there is a lil buffer zone thats what the gases do
if you have slots or vents then the gases are released and exit the rotor better decreasing brake temp and INCREASing brake performance
the lower temp helps prevent "glazing" too hot for the pad melts rotors get to hot melt kinda not sure which one probably the pad and this high brake temp and increase in brake gases prevent you from stopping(trust me its not fun i've done it you can't stop at all)
so hence the reason for performance rotors
but to BENEFIT from them it has to be under high speed/heavy braking
to get a benefit not just every day driving
post Feb 15, 2005 - 5:31 PM
shid
Joined Jan 8, '04
From LA
QUOTE(playr158 @ Feb 15, 2005 - 9:49 PM)
if you have slots or vents then the gases are released and exit the rotor better decreasing brake temp and INCREASing brake performance[right][snapback]246381[/snapback][/right]
Slots aren't for that purpose, slots slice off a thin layer of the break material
This post has been edited by shid: Feb 15, 2005 - 5:31 PM
post Feb 15, 2005 - 6:04 PM
QUOTE(shid @ Feb 15, 2005 - 5:31 PM)
[right][snapback]246383[/snapback][/right]
shid your an idiot go learn about brakes -(you can't even spell the word)
thats not why they are there you idiot
post Feb 15, 2005 - 7:47 PM
shid
Joined Jan 8, '04
From LA
it was a quick typo; I make it a lot.
on that note, it should be: Shid you're an idiot.
Not, shid your an idiot
and uhh, it IS why they're there, you dumbsh!t.
here's the 411 for your punk@$$ on how braking systems work.
Brakes need heat to work, but too much heat will lesson the ability of the pad to grab the disc (this is brake fade)- this causes an increase in stopping distance. Cross drilled rotors are designed with a specific drill pattern that enhances air flow.
Done right, this does not affect the integrity of the rotor and at the same time insures maximum cooling for the disc.
Done poorly, like the ebay "brembo" rotors he's talking about, it will SIGNIFIGANTLY decrease the structural integrety, and do nothing for brake ventalation.
Drilled rotors don't magically make your car stop quicker, nor will they make the car stop quicker in all conditions.
As for SLOTTED rotors, the slots clean the friction material (those are the BRAKE PADS) by slicing off a thin layer, they do NOTHING TO HELP COOL. They do in fact, have the opposite effect
The face grooves slice the brake pad material, allowing the pad to bite harder into the disc, thereforce causing an increase in the disc temperature.
What does that mean? It means that it helps competition vehicles bring the pads and the disc up to optimal operating temperatures. It will NOT help anyone without a big brake kit, etc.
it won't help you stop quicker either
and it will decrease your pad life.
Go sit in the corner and cry.
This post has been edited by shid: Feb 15, 2005 - 7:52 PM
post Feb 15, 2005 - 7:53 PM
haha from you
more like laugh at you....
i'm not goin to get into this with you your not worth it
as for the question
if you want crossed and slotted rotors go to NOPI those are good but shipping take time
2 don't get ebay rotors they are known to break
and dangerous
3) big brake kits are good the 7th gen front will fit on your front you just can't have 14s or 15s i think
you need at least 16
i could be mistaken and the 15s will work
shid
Joined Jan 8, '04
From LA
get into it, you're wrong and you know it.
Some reading material for you guys
http://auto.howstuffworks.com/brake.htm (basic)
http://www.drifting.com/forums/printthread.php?t=6920 (A good, knowledgable forum discussion on the different types of discs)
http://scirocco.dyndns.org/faq/brakes/pulp...on/pfpage1.html (Common misconceptions about brakes and the answers)
And for the record, your common misconceptions player could get someone killed, so could buying ebay rotors.
This post has been edited by shid: Feb 15, 2005 - 8:11 PM
post Feb 15, 2005 - 8:21 PM
madmods
Joined Mar 19, '04
From Scottsdale, Az
I got brembos, and gurantee you those aint brembos!
post Feb 15, 2005 - 9:09 PM
word^^ mads
but ummm my advice will get no one killed
and it hasn't so far i have about a 98% great advice
giving here just talk to a bunch of members i havn't killed a person
and i have given great advice and helped
i've traveled far to help people i've even found a garage for sumone to work
i've found things at cheaper prices for them
all in all you have contributed how much to this community?
personally lets look my car to yours
what do you have a touch screen and a fake photochopped woman?
and i have CROSSED/SLOTTED rotors with EBC green stuff pads
arospeed coilovers
kyb gr2 shocks
18" rims
gt4 suspension brace?
and i've done ALL MY OWN WORK with no digital girls
body/interior/suspension/engine
yea i think your outta your league
post Feb 15, 2005 - 9:19 PM
shid
Joined Jan 8, '04
From LA
Crossdrilled slotted rotors are all show, they lose too much actual surface brake area.
Just because I haven't done that work to my car, doesn't mean I don't know what I'm talking about. You obviously have no clue.
Furthermore, I didn't bring your car into this, why are you bringing mine? Your car looks like a POS to me, but you don't hear me saying that affects your knowledge of brakes. Thats childish playr. Furthermore, if your knowledge of wiring is anything like your knowledge of brakes, you couldn't wire up a touchscreen if it was plug and play.
Either get back to the topic at hand- disprove my correct explanation of braking systems Crossdrilled/slotted either. Or admit you're wrong, and shutup.
This post has been edited by shid: Feb 15, 2005 - 9:27 PM
post Feb 15, 2005 - 9:26 PM
oo i do since i only know 90% of shops in the fairfax area which is a population of like i dunno a mill or so
then
hmm i work in an auto store
hmmm i know most performance shops here
i know enough people in the car business to wrap your head to your butt
and that i have MECHANICS in my FAMILY
so i've been in this for awhile
post Feb 15, 2005 - 9:28 PM
shid
Joined Jan 8, '04
From LA
player, shutup.
Its not who you know, but what you know. You may say you know a lot of people, but until you actually talk like you KNOW something (and saying you have USELESS and ONLY show crossdrilled/slotted rotors- which actually DECREASE braking power doesn't help); you have no worth in my book.
This post has been edited by shid: Feb 15, 2005 - 9:30 PM
Lo-Fi Version Time is now: May 24th, 2026 - 11:34 AM
