Feb 15, 2005 - 12:02 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 16, '04 From Los Angeles Currently Offline Reputation: 8 (100%) |
What manifold and down pipe would be better to use a 3sgte from a celica or an mr2? i would assume a celica.
But seeing as ill have to run custom exhaust can i just run it off of an mr2 and not worry about the way the down pipe points at its end. i want to use this http://cgi.ebay.com/ebaymotors/ws/eBayISAP...&category=33742 but its probably for an mr2 even tho it says celica. ive been thinking about finding a manifold and down pipe that came from a 3sgte that was in a celica but i havnt seen many of those out there. This is why ive been looking at mr2 stuff. Are the manifold and DP from a celica all track the same as the mr2? i doubt it. thanks in advanced |
urbandork which manifold did you use? 5sfte ppl Feb 15, 2005 - 12:02 AM
LewFX does your car have to have a turbo in order for th... Feb 15, 2005 - 3:54 AM
urbandork QUOTE(LewFX @ Feb 15, 2005 - 8:54 AM)does you... Feb 15, 2005 - 11:13 PM
1bwilson It should work fine. As long as you dont have any... Feb 15, 2005 - 9:20 AM
3sgtegts Why doesn't it fit into 3rd gen 3SGTE? Feb 16, 2005 - 4:16 AM
1bwilson QUOTE(3sgtegts @ Feb 16, 2005 - 2:16 AM)Why d... Feb 16, 2005 - 9:04 AM
3sgtegts Oh ok
thanks Feb 16, 2005 - 11:15 AM
shid ?? it is? So all the manifolds for 3rd gen 3sgtes ... Feb 16, 2005 - 11:44 AM
1bwilson As far as I know the 2nd gen is a 6 bolt pattern a... Feb 16, 2005 - 11:52 AM
urbandork do i have even more to worry about now? some one c... Feb 16, 2005 - 2:58 PM
4wheelWOnder what type of engine do you have agin? Feb 16, 2005 - 3:45 PM
shid Well, this might sound extremely stupid, but I cou... Feb 16, 2005 - 4:01 PM
presure2 the problem with that tubular manifold is two fold... Feb 16, 2005 - 4:29 PM
urbandork Well i gave that tubular set up thinking few days ... Feb 16, 2005 - 8:08 PM
rjbibeau you gotta chop the upper corner of the manifold t... Feb 24, 2005 - 6:59 PM
presure2 your gonna wanna stick with a gen 2 mainfold from ... Feb 24, 2005 - 7:38 PM
urbandork why not any other generations i take it because of... Feb 24, 2005 - 11:00 PM
rjbibeau i'm using an mr2 manifold right now and there ... Feb 24, 2005 - 11:15 PM
presure2 the the 165(1st gen)manifold is for a single entry... Feb 25, 2005 - 7:04 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 23rd, 2026 - 11:09 PM |
