> what clutch should I use?
post Feb 16, 2005 - 4:18 AM
3sgtegts
Joined Dec 10, '04
From Ottawa
If I have a 94 celica GT with 3rd gen 3SGTE, what clutch should I get?
clutch for the MR2T & GT4? or cluth for the 2.2L 5SFE Celica?
and what do you suggest clutch for my car?
post Feb 16, 2005 - 8:44 AM
ZoomZoom
Joined Apr 7, '04
From Toronto
what transmission are you using?
if you're using the E153 then you can use the mr2 clutch
If you're using the S54 , then you have to use the 5sfe tranny.
post Feb 16, 2005 - 9:00 AM
QUOTE(ZoomZoom @ Feb 16, 2005 - 8:44 AM)
[right][snapback]246711[/snapback][/right]
if you are using a GT tranny, then you will have to have a custom clutch kit made.
5sfe:
clutch
throwout bearing
alignment tool
3sgte:
pressure plate
flywheel
make sure you look at the TQ specs of any new clutch you have, because most 5sfe clutches will not be able to hold all that power for long. I called Spec and they are making me a custom stage2 3sgte clutch with the splines to fit my 5sfe tranny.
post Feb 16, 2005 - 11:02 AM
3sgtegts
Joined Dec 10, '04
From Ottawa
Oh
I am thinking of using a MR2 tranny(LSD) since the tranny comes with the engine.
But I was told that if I use that tranny to my car i won't be take advantage of the LSD function so i was told to sell it and just use the GT tranny.
Is that right?
and if I use the MR2 tranny what clutch should I get?
post Feb 16, 2005 - 12:45 PM
jgreening
Joined Jan 17, '04
From Illinois
No offense but you really need to do more research before you buy anything else. The statement above is false. GT trannies do not have LSD unless it is an aftermarket one. If you bought a 3rd gen MR2T clip, the tranny that comes with that has LSD. You definitely want to use that rather than the GT tranny. The only reason you wouldn't use a MR2T tranny is cost.
P.S. Please post a pic of your motor and tranny. Or have you not bought it yet?
I have an idea. If you don't know what you are talking about, dont post without a disclaimer. Propogating misinformation on the board is a bad thing. The last line of your post is really bad. First, it doesn't make sense because the S54 IS the 5sfe tranny. If you meant "5sfe clutch" then you should read Lagos' post.
This post has been edited by jgreening: Feb 16, 2005 - 12:50 PM
post Feb 16, 2005 - 1:15 PM
3sgtegts
Joined Dec 10, '04
From Ottawa
Yeah man, that's what i meant.
Of course I know that the GT tranny doesn't have the LSD.
ButI asked that question because I was told by someone that my celica can't take advantage of the LSD function from MR2 tranny.
So if I use that tranny, can i just get the MR2 turbo clutch for my car?
I already bought the engine(3rd gen) with LSD tranny.
post Feb 16, 2005 - 1:19 PM
yes, then you and just use an mr2 turbo clutch kit.
you need to make some hybrid axels tho.
post Feb 16, 2005 - 2:32 PM
3sgtegts
Joined Dec 10, '04
From Ottawa
whats does it mean?
This post has been edited by 3sgtegts: Feb 16, 2005 - 2:44 PM
post Feb 16, 2005 - 3:46 PM
http://www.geocities.com/zegoat2000/HOMEPAGE.html
check out that site. should give you some good info on the swap.
what are you going to do about the wiring ?
post Feb 17, 2005 - 2:49 AM
3sgtegts
Joined Dec 10, '04
From Ottawa
Wiring for the swap u mean?
I am taking it to a shop near my place.
Thanks for the website and all the help.^^
Lo-Fi Version Time is now: September 13th, 2026 - 9:30 AM
