Feb 16, 2005 - 11:43 PM
Enthusiast ![]() ![]() Joined Aug 26, '04 From St. Cloud, Minnesota Currently Offline Reputation: 0 (0%) |
Everyone out there with convertables, Have you notice that when you go above 40MPH you can hear wind whistling through the windows.
My does it and I tried to put tape around the windows edge and it helps, but now I don't want to be driving around with a taped window. So is there any insulation or any other options? |
Feb 17, 2005 - 12:54 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 8, '04 From LA Currently Offline Reputation: 0 (0%) |
It's a vert, you'll never fix that.
Sorry, jus the truth. A certain amount of it is actually wind going over the canvas top |
Feb 17, 2005 - 1:17 AM
There are things you can do. The most productive solution is to take it to a place that specializes in convertible tops and have them replace all the seals and adjust the alignment. I get very little wind noise in mine.
Feb 17, 2005 - 1:44 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 1, '02 From Seattle, WA Currently Offline Reputation: 0 (0%) |
I have some luck with opening and the closing the windows if you have opened that door. It doesnt eliminate the problem, but it helps a bit for me.
But as said, its a vert, you have to live with it. -------------------- Its Orville's Celica, i just drive it... |
Feb 17, 2005 - 2:14 AM
QUOTE(orvillescelica @ Feb 17, 2005 - 6:44 AM) I have some luck with opening and the closing the windows if you have opened that door. It doesnt eliminate the problem, but it helps a bit for me. But as said, its a vert, you have to live with it. [right][snapback]247126[/snapback][/right] This actually always helps me too |
Feb 17, 2005 - 5:47 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 19, '04 From Scottsdale, Az Currently Offline Reputation: 2 (100%) |
I will also add that the top has an adjustment where it clamps down. I had the same wind problem and adjusted the top and that helped a bit. i actually cant hear the wind because my stereo is so fooking loud.....even with the top down
Feb 17, 2005 - 7:44 PM
QUOTE(madmods @ Feb 17, 2005 - 10:47 PM) I will also add that the top has an adjustment where it clamps down. I had the same wind problem and adjusted the top and that helped a bit. i actually cant hear the wind because my stereo is so fooking loud.....even with the top down [right][snapback]247393[/snapback][/right] Woah mad, where's this adjustment at!?! |
Feb 17, 2005 - 8:30 PM
QUOTE(shid @ Feb 18, 2005 - 12:44 AM) QUOTE(madmods @ Feb 17, 2005 - 10:47 PM) I will also add that the top has an adjustment where it clamps down. I had the same wind problem and adjusted the top and that helped a bit. i actually cant hear the wind because my stereo is so fooking loud.....even with the top down [right][snapback]247393[/snapback][/right] Woah mad, where's this adjustment at!?! [right][snapback]247454[/snapback][/right] Its on the 2 hooks that attach the top to the frame. they are threaded |
Feb 17, 2005 - 8:32 PM
OMFG, if it weren't raining I'd go out andplay with those things right now
Feb 19, 2005 - 7:13 PM
Enthusiast ![]() ![]() Joined Jul 28, '04 From Miramar Florida Currently Offline Reputation: 0 (0%) |
I guess the question is answered...
Feb 20, 2005 - 12:49 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 5, '03 From South TX. Currently Offline Reputation: 14 (100%) |
lol, i couldnt adjust mine, i noticed when i bought the car that it was possible, but the threads were all rusted so i just added cardboard to the hooks for it to clamp harder and it worked.
the window wind is unfixable if your seals are bad, and oh yea.....its a vert:P |
Feb 20, 2005 - 7:42 PM
Enthusiast ![]() ![]() ![]() Joined Feb 8, '05 From Cambridge, ON, Canada Currently Offline Reputation: 1 (100%) |
yeah i noticed that too in my car on the way home. its not too bad though, i just turned the music up and thats okay. it was annoying at first but ill get used to it.. lol
-------------------- lissa | 1997 Celica Convertible
*My other ride is your boyfriend* ;) |
Feb 23, 2005 - 4:09 PM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 19, '05 From Indianapolis Currently Offline Reputation: 0 (0%) |
the stock stereo is a piece, i think. compared to my ole beloved Eagle Talon's. then again hatches make music sound all the much better
| Lo-Fi Version | Time is now: September 3rd, 2026 - 8:26 AM |
