> Odd clutch noises..., Help? New clutch, making noises...
post Feb 17, 2005 - 4:16 PM
sdragon007
Joined Sep 30, '04
Good afternoon, ladies and gentlemen.
I post to ask for your help in deciphering a mystery on my 6th gen celica.
Two weeks ago, I had a Centerforce Dual-Friction clutch installed onto my vehicle. I have driven approximately 150 miles on this new clutch and I've noticed an odd noise coming from the clutch.
When the vehicle is in neutral (engine idle, stick in neutral, clutch out) there is a whining/scratching noise coming from the clutch. When I depress the clutch (engine idle, stick still in neutral, clutch in) the noise promptly stops. When I release the clutch (engine idle, stick neutral, clutch out) the noise whines up (as if it is spooling up with the clutch) and remains steady.
Anybody have any similar experiences with new clutches?
Specs:
1996 Celica GT
2.2L Engine
81k miles
post Feb 17, 2005 - 4:18 PM
throw out bearing.
sdragon007
Joined Sep 30, '04
Oh, and here's the link to my previous topic on the clutch install:
http://www.6gc.net/forums/index.php?showtopic=20475
Thanks,
Ed
post Feb 17, 2005 - 4:19 PM
sdragon007
Joined Sep 30, '04
What about the throw-out bearing?
Anything wrong? Normal? Imminent engine implosion?
post Feb 17, 2005 - 5:29 PM
Mr_E
Joined Nov 16, '04
From UK
Thrust/Release bearing is not right.
Did they fit a new one when the clutch went in?
JDM ST205
Blitz Spec NUR Exhaust, somewhere over $1000
Needing another one 18000 miles later, bloody annoying.
post Feb 17, 2005 - 7:44 PM
when you install the bearing there are a few places where you have to apply grease to it and the fork.
if you are lazy, you can turn the clutch pedal height adjuster untill the sound goes away.
Lo-Fi Version Time is now: July 29th, 2026 - 8:16 PM
