Apr 1, 2003 - 8:01 PM
![]() Enthusiast ![]() ![]() Joined Feb 11, '03 From Phila, PA Currently Offline Reputation: 0 (0%) |
I just read this article in Import Racer about the Zex Dry Nitrous System and this injector air amplifier. The injector is just a Zex cone filter with a spot at the top to attach the dry nitrous nozzle instead of having to drill a hole in the side of an intake pipe. I'm reading this how-to-article and it looks like it has to be the easiest. The cone just then fits onto your intake. The nitrous is activated when you have the throttle wide open which i think is perfect. This is like a turbo anytime you want it and takes a few hours to hook up the systems with its NMU (nitrous managment unit). The new air amplifier helps air flow too and doesn't require drilling into your intake to place the injector. This has to be the easiest power upgrade for the claimed 55, 65, or 75 hp gains depending on injector choice. I wanted to know what you all thought of it cause I need some power increase on the ol' 7AFE.
This post has been edited by Milds3vn: Apr 1, 2003 - 8:31 PM |
Milds3vn Zex Dry Nitrous System Apr 1, 2003 - 8:01 PM
macavely well thanks to the 7afe superlow compresion ratio ... Apr 1, 2003 - 8:32 PM
FallenHero nitrous does no damage if you run like a 45 shot o... Apr 1, 2003 - 10:04 PM
95STCelica I'd love a simple 45 shot that way I could han... Apr 1, 2003 - 10:17 PM
snadman I think it's been said and quoted many times b... Apr 1, 2003 - 11:27 PM
97sccelica yeah, it adds about the same power as a turbo, exc... Apr 2, 2003 - 12:13 AM
FallenHero Yea, compression on the 7a and 5s are 9.5-1. BUT,... Apr 2, 2003 - 12:20 AM
macavely i think the 7afe has and 8.0:1 comprestion i could... Apr 2, 2003 - 4:17 AM
jayi12-15psi QUOTE snadman Posted on Apr 1, 2003 - 8:41 PM
----... Apr 2, 2003 - 12:44 PM
FallenHero not really. Read. That much nitrouse will blow y... Apr 3, 2003 - 12:58 AM
ibjohn85 ok you guys I've been running the zex kit for ... Apr 3, 2003 - 10:09 AM
ibjohn85 oh and for the air filter dry thingy...I think tha... Apr 3, 2003 - 10:29 AM
streetdreamz94 how is it 90% show w/ a purge kit and only 10% go?... Apr 6, 2003 - 10:32 PM
FallenHero Exactly. I'd never have nitrous without a pur... Apr 6, 2003 - 11:23 PM
ibjohn85 noooo I'm just saying when I'm out and abo... Apr 6, 2003 - 11:46 PM
FallenHero Ever had the nitrous leak into your cabin. Apr 7, 2003 - 12:25 AM![]() ![]() |
| Lo-Fi Version | Time is now: July 9th, 2026 - 1:27 AM |
