> Superchargers, 3s-gte
post Feb 22, 2005 - 9:55 PM
spunky393
Joined Apr 22, '04
From illinois
Did somebody, anybody, make a powerful and well proven over the top supercharger for the 3s-gte engine. (i'm not stupid, i don't like turbo's, i rather have a supercharger) Unlike most people, i know both can't be put on
post Feb 22, 2005 - 10:43 PM
shid
Joined Jan 8, '04
From LA
Hehe not on the 3sgte maybe (but then, it's also never been tried.. I think someone on toyotanation was in their mr2 for a while..), but on other cars, you can put both on.
i think the mini has a kit for it?
(I know not very helpful, but its all I could add)
post Feb 22, 2005 - 10:49 PM
QUOTE(spunky393 @ Feb 22, 2005 - 6:55 PM)
[right][snapback]249058[/snapback][/right]
Why can't a 3S-GTE be twin-charged? I've seen 4A-GE engines twin-charged before.
post Feb 22, 2005 - 11:16 PM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
QUOTE(Coomer @ Feb 23, 2005 - 3:49 AM)
[right][snapback]249087[/snapback][/right]
Ditto, you can in theory have a 3s-gtze. You could take the supercharger from a 4a-gze and put it on a 3s-ge if you wanted to make a 3s-gze, but that would be a lot of work and some modification. I'm not an expert on the subject by any means though.
post Feb 22, 2005 - 11:26 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
I personally dont think smaller engines should have superchargers, there not going to put out enoughgains as an larger , concidering it need power to make power.
post Feb 22, 2005 - 11:34 PM
spunky393
Joined Apr 22, '04
From illinois
What's the point of twin charging an engine? won't the pressure equal out for one point, and it'll be two much for another?
post Feb 22, 2005 - 11:49 PM
spunky393
Joined Apr 22, '04
From illinois
QUOTE(Coomer @ Feb 22, 2005 - 10:49 PM)
Here's the page with a twin-charged 20V 4a-gze
4th one down
post Feb 23, 2005 - 12:45 AM
macavely
Joined Nov 4, '02
QUOTE(Digndoug @ Feb 22, 2005 - 11:26 PM)
[right][snapback]249115[/snapback][/right]
i have dis agree with that.... its a matter have the right set up ... and for street use i think a inline 4 with a SC at around 8-10psi is a lot better then a turbo at the same psi .. but then again thats just me
post Feb 23, 2005 - 12:59 AM
FallenHero
Joined Dec 26, '02
From Alabama
QUOTE(CheesyLobster @ Feb 22, 2005 - 9:16 PM)
[right][snapback]249107[/snapback][/right]
4ag supercharger is tooo small for the 3s' wanted power levels. It might work, but ehh...
QUOTE(Digndoug @ Feb 22, 2005 - 9:26 PM)
agreed. Smaller engines have to excert more power to make power because the lack of torque. Think about running your AC while trying to accelerate. The only diff is the SC would eventually make boost.
QUOTE(spunky393 @ Feb 22, 2005 - 9:34 PM)
[right][snapback]249120[/snapback][/right]
Twin charging: The SC is to make the power in the lower RPM's and the turbo is for the higher RPM's. Basically, the SC helps the turbo to spool.
post Feb 23, 2005 - 1:05 AM
i would agree with turbo is good
supercharger is good
twin charging is ok but eh not a fan
i watched a race str-4 at 18-20 psi
against a SC tib i'm not sure of the boost
but when they took off the tib got the line on him
then srt-4 starts to pull when turbo hits
but then dies off as boost is lost in high RPM
tib pulls non stop only reason i like the sc cause no matter what RPM it always pulls
post Feb 23, 2005 - 1:15 AM
shid
Joined Jan 8, '04
From LA
How can you not be a fan of twin charging? if its possible, there's never any reason not to.
the supercharger spools up a large ass turbo, which takes over at the higher rpms- you have boost through the entire rpm range, it's always pulling.
There's no downsides, except cost and difficulty.
post Feb 23, 2005 - 7:07 AM
Mr_E
Joined Nov 16, '04
From UK
I know a guy with a custon 3S-GZE if it helps.
JDM ST205
Blitz Spec NUR Exhaust, somewhere over $1000
Needing another one 18000 miles later, bloody annoying.
post Feb 23, 2005 - 11:37 AM
FallenHero
Joined Dec 26, '02
From Alabama
QUOTE(Mr_E @ Feb 23, 2005 - 5:07 AM)
[right][snapback]249242[/snapback][/right]
how is it Vs. the four?
post Feb 23, 2005 - 2:46 PM
Mr_E
Joined Nov 16, '04
From UK
QUOTE(FallenHero @ Feb 23, 2005 - 11:37 AM)
[right][snapback]249281[/snapback][/right]
Struggles for traction in the lower gears. Damn quick once it's rolling.
Cost him more than simply selling the ST202 and buying a decent ST205 would have done, but that wasn't the point.
JDM ST205
post Feb 23, 2005 - 6:12 PM
4wheelWOnder
Joined Jan 1, '05
From rapid city, SD
argh, i went by this one website that had a supercharger for the 3s, engine series. It was about 1500 or 4500, cant remember, but ill try to find it again..........
post Feb 23, 2005 - 6:18 PM
Hanyo
Joined Aug 16, '03
From Bay area
i wonder why no one has done a 7afze?
wouldn't the sc 14 supercharger create decent amount of boost for the 7afe.
post Feb 23, 2005 - 6:50 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
I think the supercharher on the 5S is the best way to go. The engine already has a lot of torque but no high rpm power, so work with what you got. But the 3S is a higher winding engine, taller powerband. But it would be really cool to put a SC on the 3S-GE. There's all kinds of places you can go to get them made for your car, well, maybe not all kinds, but they are out there. If you go with the external(not sure if right term), instead of the manifold kind, you could use just about any supercharger. You'd just have to run custom mounts. I'm working on this with my 5S now. I'll get back with everyone eventually on how it works and a "how to" thing.
Live Free, Be Happy
post Feb 23, 2005 - 8:06 PM
FallenHero
Joined Dec 26, '02
From Alabama
well, it's hard to build the right brackets and get the pully in the right place. Plus finding the right belt would be a huge problem.
post Feb 23, 2005 - 9:01 PM
Rjb23
Joined Feb 8, '04
From KY
QUOTE(Bigmeanbulldog55 @ Feb 23, 2005 - 11:50 PM)
[right][snapback]249432[/snapback][/right]
Isn't there already a supercharger kit for the 5s?
post Feb 23, 2005 - 9:24 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
QUOTE(Rjb23 @ Feb 23, 2005 - 9:01 PM)
[right][snapback]249467[/snapback][/right]
Yes there is. You can find it by doing a search for 5s-fe supercharger. I just have a blower and I want to put it on my car.
Live Free, Be Happy
Lo-Fi Version Time is now: July 9th, 2026 - 12:16 PM
