> ??Should I Mold back bumper??, YES or No
post Feb 25, 2005 - 11:52 PM
XxAxnCelica95xX
Joined Dec 28, '04
From New Jersey
should i mold my back bumper .i saw alot of car with it mold on but then again i dont know how it goes lik does it worth it and soo forth....anybody got any ideas....thanks in advance.. biggrin.gif
This post has been edited by XxAxnCelica95xX: Feb 25, 2005 - 11:53 PM
As the time goes by
My life change...
I hope i wont change
Nor my heart
but it is broken..wat can i do..
IT life...I hate it...but i lov my creation
Replies (1 - 9)
post Feb 26, 2005 - 12:27 AM
pr_caralho
Joined Jan 24, '05
From toronto,ontario canada
QUOTE(XxAxnCelica95xX @ Feb 25, 2005 - 11:52 PM)
[right][snapback]250291[/snapback][/right]
depends, if u need to remove your bumper you'll have one heck of a time doing it
Go leafs go
post Feb 26, 2005 - 2:04 AM
madmods
Joined Mar 19, '04
From Scottsdale, Az
yes
post Feb 26, 2005 - 8:50 AM
XxAxnCelica95xX
Joined Dec 28, '04
From New Jersey
fiberglass reinforced body filler
sand paper lots of time
and lightweight body filler for the very very end buy a gallon
the fiberglass kind either long strand (guerilla hair) of the short strand
is this the only things i need to do it...am i messin anything???
As the time goes by
My life change...
Nor my heart
post Feb 26, 2005 - 2:40 PM
creis
Joined Jan 10, '04
From Shoreline, WA
dont forget that wile modling in body peaces may look cool, its very easy to crack the molds, even if you do a good job, parts like the bumper are not molded from stock because they need to be able to flex to releave pressure, and not dent/crack.
I'm not gana mold my kit on when I put it on simply because I think it looks just fine as it is, and if I hit something, even just a bump in the road it would couase more damage if it could not flex.
post Feb 26, 2005 - 3:06 PM
celicagurl152003
Joined Oct 12, '04
From Montgomery, AL
in my opinion i like the body lines so i wouldn't mold it. plus if you get hit you will have a hell of a time taking it off. i think it will look better with outmolding, but all in same that's my opinion.
Later,
-Christina
post Feb 26, 2005 - 3:27 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
I like the look of the molded better, but would never do it. sence i have owned my car, it has been backed into at least 8 times that i know of. Keep in mind if some one just bumps it, it might crack and screw up your paint. I would only do it if it were like an only show car or somthing.
post Feb 26, 2005 - 3:52 PM
madmods
Joined Mar 19, '04
From Scottsdale, Az
mold, mold, mold. The only other thing I can think of is a long board sander, we use paint sticks(they work good and the cheese grater to knock down the filler before it hardens. As far as cracking goes, After you mold, jack up the car and put kitty hair from behind. My kit has cracked, due to major rubbing when I get off driveways. My car is too low, but I like it that way.
This post has been edited by madmods: Feb 26, 2005 - 5:40 PM
post Feb 26, 2005 - 8:34 PM
prpnum1
Joined Aug 7, '04
From US
the back is fine. if someone hits you from the back they have to pay for it anyways so do it. and it still has the same body lines but without the gaps.
post Feb 27, 2005 - 9:19 AM
creis
Joined Jan 10, '04
From Shoreline, WA
if its intalled right there should not be any gaps, just a nice fine line
Lo-Fi Version Time is now: September 11th, 2026 - 6:17 PM
