Feb 26, 2005 - 12:16 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jul 8, '04 From Durham, NC Currently Offline Reputation: 6 (100%) |
Hi,
I recently put in a Pioneer HU in my car, and there was a wire coming out of the back that said "Power Antenna". Well, I thought that the wire coming from inside my dash that was for the antenna was some sort of plug shaped wire.. If you know what I mean. Well, I tried touching that connector to the bare wire of the wire coming out from the stereo, and it did not work. How can I get my antenna functioning?? Yes, I did try searching for it but I couldnt find anything. So please dont yell at me, just help me out. Thanks, Rob -------------------- ![]() |
Feb 26, 2005 - 1:00 PM
Enthusiast ![]() ![]() ![]() Joined Aug 18, '04 From St. Louis, Missouri Currently Offline Reputation: 0 (0%) |
there are 2 wires lableled "power antenna." i know because with my Pioneer HU, the antenna would go up when i listened to cd's so i installed a switch for my antenna. i put it on one of the wires and it didnt work. i then found another wire labeled the same and it worked. just try to find the other "power antenna" wire.
Feb 26, 2005 - 11:58 PM
i've checked all the wires, and mine only has one..
what should i do -------------------- ![]() |
Feb 27, 2005 - 12:37 AM
Enthusiast ![]() ![]() Joined Dec 19, '02 From West of Atlanta Currently Offline Reputation: 1 (100%) |
The big fat wire with the connector is your antenna. It get hooked into the back of your hu. There should be a place it fits into. In the stock wire harness look for 2 wires one is pink/blue and one is black/red. Connect the blue power antenna wire to both of the wires in the stock harness. They both need the 12vdc + from the radio to activate the stock antenna to got up.
| Lo-Fi Version | Time is now: August 31st, 2026 - 5:00 PM |
