> 7agte build diary, my progress so far
post Feb 28, 2005 - 3:46 PM
nik
Joined Sep 30, '02
Feb 25 2005
recieved
intake manifold w/ throttle body (small port)
stock cams gears (small port)
oem FPR
fuel rail (big port)
(( from Bee aka kwanza ))
big port head from a 4agze ebay
Feb 28 2005
i drop the head off at F-Tuning (local shop) to get the head pressure checked if good the head will get fully tuned new valve spring P&P etc.
sent money off to a MR2 member for a
AE101 LEVIN MAP/DLI 4AGZE 1992+ MAP/DLI engine wiring harness
also bought 440 cc 7mgte injectors
4ag AEM adjustable cam gears
talking to frotou about a custom manifold
Need to talk to the shop about what cams to use i'm thinking 256 intake 243 exhaust
March 1 2005
things a need to do
track down DLI coils and distributor
track down a 92+ levin Map ecu ( any help on this one will be a big help)
This post has been edited by nik: Mar 11, 2005 - 12:39 PM
- nik   7agte build diary   Feb 28, 2005 - 3:46 PM
- - Kwanza26   Hey nik... that manifold is smallport. I told you...   Feb 28, 2005 - 4:34 PM
|- - nik   QUOTE(Kwanza26 @ Feb 28, 2005 - 2:34 PM)Hey n...   Feb 28, 2005 - 5:05 PM
- - FallenHero   small port=more velocity less volume. the large p...   Feb 28, 2005 - 11:00 PM
- - nik   UPDATE March 3 2005 found a 3 gen 4agze map ecu o...   Mar 3, 2005 - 3:45 PM
- - nik   this is what i want my motor to look like   Mar 7, 2005 - 6:08 PM
|- - FallenHero   QUOTE(nik @ Mar 7, 2005 - 4:08 PM)this is wha...   Mar 7, 2005 - 10:19 PM
|- - nik   QUOTE(FallenHero @ Mar 7, 2005 - 8:19 PM)QUOT...   Mar 15, 2005 - 4:03 PM
- - nik   update: March 10 2005 3rd gen 4agze map ecu cam...   Mar 11, 2005 - 12:37 PM
- - nik   well there is a company in canada doing 7ag conver...   Mar 14, 2005 - 4:21 PM
- - nik   update March 15 2005 i won some new 8.0:1 4agze p...   Mar 15, 2005 - 1:12 PM
|- - doGGy   Nik, if ya going with the same Exhaust Mani, be pr...   Mar 17, 2005 - 4:47 PM
- - FallenHero   wait, you are going to cut off the B-series flange...   Mar 15, 2005 - 3:33 PM
|- - nik   QUOTE(FallenHero @ Mar 15, 2005 - 1:33 PM)wai...   Mar 15, 2005 - 3:56 PM
- - FallenHero   nice. that's what I like to see. Outside the...   Mar 16, 2005 - 10:38 PM
|- - nik   QUOTE(FallenHero @ Mar 16, 2005 - 8:38 PM)nic...   Mar 17, 2005 - 10:16 AM
- - FallenHero   hey, if it works for you that rocks. I just want ...   Mar 17, 2005 - 2:55 PM
|- - nik   QUOTE(FallenHero @ Mar 17, 2005 - 12:55 PM)he...   Mar 17, 2005 - 5:27 PM
- - nik   Picture from inside TEAM 66 this is the bigport...   Mar 28, 2005 - 11:05 AM
- - nik   update April 2 2005 went and bought a block wit...   Apr 5, 2005 - 10:43 AM
- - nik   update april 14 2005 i got the block all torn a...   Apr 14, 2005 - 9:39 AM
- - playr158   how much is the bore costing you? and isn't t...   Apr 14, 2005 - 10:48 AM
|- - nik   QUOTE(playr158 @ Apr 14, 2005 - 8:48 AM)how m...   Apr 14, 2005 - 11:06 AM
- - playr158   oh gotcha used the pipes but cut them off and used...   Apr 14, 2005 - 11:24 AM
|- - nik   QUOTE(playr158 @ Apr 14, 2005 - 9:24 AM)oh go...   Apr 14, 2005 - 11:32 AM
- - nik   I'm going in today for an update on everything...   Apr 14, 2005 - 12:45 PM
- - nik   update my rod got sent out to have custom ones m...   Apr 18, 2005 - 1:57 PM
- - Mike431635   Hey nik, how close are the runners on that B-serie...   May 1, 2005 - 9:21 PM
- - FallenHero   the 7afe and 4age heads are remarkably similar. T...   May 1, 2005 - 11:03 PM
- - Kwanza26   The spacing between the B series manifold and 4AG/...   May 2, 2005 - 12:01 AM
|- - FallenHero   QUOTE(Kwanza26 @ May 1, 2005 - 10:01 PM)The s...   May 2, 2005 - 12:12 AM
|- - Kwanza26   QUOTE(FallenHero @ May 2, 2005 - 5:12 AM)QUOT...   May 2, 2005 - 12:22 AM
- - nik   on my manifold i had 2 options leave the oval part...   May 2, 2005 - 9:03 AM
- - playr158   i'm guessing cut it at round and branch from t...   May 2, 2005 - 11:03 AM
|- - nik   QUOTE(playr158 @ May 2, 2005 - 9:03 AM)i...   May 2, 2005 - 11:35 AM
- - nik   update 5/2/05 ordered ACT 6 puck clutch today dro...   May 2, 2005 - 2:17 PM
- - FallenHero   I am using your thread nik. So what is the bigge...   May 4, 2005 - 12:18 PM
|- - nik   QUOTE(FallenHero @ May 4, 2005 - 10:18 AM)I a...   May 4, 2005 - 12:32 PM
- - Kwanza26   I believe the largest bore you can get before seri...   May 4, 2005 - 12:40 PM
- - playr158   i was considering an 83mm bore on my 7afte when i ...   May 4, 2005 - 2:10 PM
- - nik   update last night at 12:34am I won a Stand Alon...   May 5, 2005 - 12:18 PM
- - nik   update piggy back came yesterday i just need to ...   May 11, 2005 - 9:35 AM
- - nik   update a little break down -7agte engine whp= ...   May 18, 2005 - 10:33 AM
- - doGGy   Nik, did you got back the stock rods?   May 18, 2005 - 11:12 AM
- - nik   updates and pic you guys were waiting for   May 25, 2005 - 9:44 AM
- - playr158   nice nice nice and which honda manifold is that?   May 25, 2005 - 10:25 AM
|- - nik   QUOTE(playr158 @ May 25, 2005 - 8:25 AM)nice ...   May 25, 2005 - 10:31 AM
- - playr158   i know a b-series but which one there are many di...   May 25, 2005 - 12:24 PM
|- - nik   QUOTE(playr158 @ May 25, 2005 - 10:24 AM)i kn...   May 25, 2005 - 12:43 PM
- - nik   UPDATE 05/25/05 ordered springs and titanium reta...   May 25, 2005 - 12:49 PM
- - nik   QUOTE(FAQdaWorld @ May 25, 2005 - 11:16 AM)I ...   May 25, 2005 - 1:58 PM
- - playr158   yea i noticed that you took it out   May 25, 2005 - 2:50 PM
|- - nik   QUOTE(playr158 @ May 25, 2005 - 12:50 PM)yea ...   May 25, 2005 - 3:53 PM
- - Kwanza26   That's a nice looking manifold. Hope it doesn...   May 25, 2005 - 3:53 PM
|- - nik   QUOTE(Kwanza26 @ May 25, 2005 - 1:53 PM)That...   May 25, 2005 - 4:01 PM
|- - Kwanza26   QUOTE(nik @ May 25, 2005 - 9:01 PM)QUOTE(Kwan...   May 25, 2005 - 4:17 PM
|- - nik   QUOTE(Kwanza26 @ May 25, 2005 - 2:17 PM)QUOTE...   May 25, 2005 - 4:45 PM
- - playr158   i was noting the inch that got cut out   May 25, 2005 - 4:03 PM
- - nik   he he here somemore pics the puater custom rod...   May 26, 2005 - 3:48 PM
- - frotou   Love the rods, I need them !!!!...   May 26, 2005 - 3:57 PM
- - doGGy   Nik - i love you   May 26, 2005 - 3:58 PM
- - FallenHero   I am told that oil squirters are great on some of ...   May 26, 2005 - 10:52 PM
- - Kwanza26   Them's is some nice lookin rods... ;]   May 27, 2005 - 12:01 AM
- - FallenHero   sowa.. ignition wise, I am ignorant. What is the ...   May 29, 2005 - 4:54 PM
|- - doGGy   Acurancy. Less resistance in wires and lots of ot...   May 29, 2005 - 5:18 PM
- - FallenHero   So I have seen the megasquirt guys using the dual ...   May 29, 2005 - 6:33 PM
- - Dr_Tweak   Nik, have you tried lining the B series manifold u...   May 29, 2005 - 10:46 PM
- - FallenHero   he purchased a 4age header flange and welded it in...   May 29, 2005 - 11:04 PM
|- - Dr_Tweak   QUOTE(FallenHero @ May 30, 2005 - 4:04 AM)he ...   May 30, 2005 - 7:37 PM
- - nik   sorry guys right after i posted those rod pics i l...   May 31, 2005 - 9:19 AM
- - FallenHero   yo, post up the specs on the size of those rods...   May 31, 2005 - 12:04 PM
|- - nik   QUOTE(FallenHero @ May 31, 2005 - 10:04 AM)yo...   May 31, 2005 - 12:13 PM
- - Kwanza26   One thing I should ask. Is that a 7AFE head gaske...   Jun 1, 2005 - 3:27 AM
|- - nik   QUOTE(Kwanza26 @ Jun 1, 2005 - 1:27 AM)One th...   Jun 1, 2005 - 8:54 AM
|- - Kwanza26   QUOTE(nik @ Jun 1, 2005 - 1:54 PM)QUOTE(Kwanz...   Jun 1, 2005 - 10:47 AM
- - nik   the coolent ports at the bottom of this pick the...   Jun 1, 2005 - 10:56 AM
- - nik   yeah springs and retainers are in the top end i...   Jun 3, 2005 - 4:58 PM
- - Kwanza26   I say you should get a 4AG headgasket, to avoid ho...   Jun 3, 2005 - 6:53 PM
- - Mike431635   That's a good point. I think you might want to...   Jun 3, 2005 - 11:45 PM
- - nik   QUOTE(Kwanza26 @ Jun 3, 2005 - 4:53 PM)I say ...   Jun 6, 2005 - 3:14 PM
- - Dr_Tweak   Yes but Nik, did you try lining it up with the 7AF...   Jun 7, 2005 - 12:21 AM
|- - Kwanza26   QUOTE(Dr_Tweak @ Jun 7, 2005 - 5:21 AM)Yes bu...   Jun 7, 2005 - 12:36 AM
|- - nik   QUOTE(Dr_Tweak @ Jun 6, 2005 - 10:21 PM)Yes b...   Jun 7, 2005 - 9:09 AM
- - nik   these are about 2 weeks old the cam shaft...   Jul 21, 2005 - 9:40 AM
- - FallenHero   man, is that your garage or the shop? There are p...   Jul 22, 2005 - 3:22 PM
|- - nik   QUOTE(FallenHero @ Jul 22, 2005 - 1:22 PM)man...   Jul 22, 2005 - 4:26 PM
- - nik   updated pic will be up this weekend of the car and...   Aug 18, 2005 - 10:48 PM
- - FallenHero   if the 255 is good enough for a supra, it's go...   Sep 12, 2005 - 8:13 PM
|- - nik   QUOTE(FallenHero @ Sep 12, 2005 - 6:13 PM)if ...   Sep 13, 2005 - 4:40 PM
- - Coomer   Sick project Nik! I can't wait to see this...   Sep 14, 2005 - 7:04 PM
- - presure2   QUOTEwalbro have that wine to them i wanted to go ...   Sep 15, 2005 - 9:50 AM
|- - nik   QUOTE(presure2 @ Sep 15, 2005 - 7:50 AM)QUOTE...   Sep 15, 2005 - 10:06 AM
- - presure2   QUOTEthanks for the info its just my pet peve thin...   Sep 15, 2005 - 10:25 AM
|- - nik   QUOTE(presure2 @ Sep 15, 2005 - 8:25 AM)QUOTE...   Sep 15, 2005 - 12:34 PM
- - nik   nothing to report porject still going just slowed ...   Oct 5, 2005 - 9:47 AM
- - presure2   nik, that seriously sucks big time man. hope you c...   Oct 6, 2005 - 8:15 AM
4 Pages V   1 2 3 > »
Lo-Fi Version Time is now: March 27th, 2026 - 10:34 PM
