16 Pages V  « < 12 13 14 15 16 >
> 7agte build diary, my progress so far
post Feb 18, 2006 - 10:13 AM
lilsteeg
Joined Jan 16, '06
From Lima, ohio
whats the tranny used on the 20v black top the 6 speed you should get one of those
post Feb 18, 2006 - 9:27 PM
frotou
Joined Jan 9, '04
From Quebec city, Quebec, Canada
OK , I'm not sure if I really understand what is your problem but here the way I go ;
- 4age crank gear (I think they are all the same)
-7afe oil pump and tensionner
- 944 belt
- catcams 256" in 8.5mm lift and 243" ex. 8.0mm lift
Since I don't have the chance to run and tune the car for a long time I not sure if I use the right way to set up the cam/camgears. I started with this :
also read this :
http://www.billzilla.org/engvalve.htm
Also be sure to make "your own" tdc mark on the damper .
Keep us informed
Claude
This post has been edited by frotou: Feb 18, 2006 - 9:30 PM
post Feb 19, 2006 - 1:20 PM
QUOTE(JoKeRkId613 @ Feb 17, 2006 - 9:39 PM) [snapback]395741[/snapback]
C160 Tranny? biggrin.gif 6 Speed 7A-GTE. I like the sound of that for some reason...
I hear they're not that much more durable than the other C-series trannies.
Nik, what about an E51 or E58?
post Feb 19, 2006 - 3:04 PM
doGGy
Joined Oct 28, '02
From Europe, Lithuania
did the tranny go out even with all the work you did to it romas?
Lol, yea it did, even with all the efford what i put using Ceramic synchros, and all the promises the guy who reworked my tranny gave about these synchros - it all started to went down after first 600 miles.... but still - 3 gear synchro is the one who died first, second one lasted longer... But im still thinking what this happend not cuz of the power and etc - but cuz of useing a short shift (hand moves faster then the leg, and this leaves to switching the gear with half way pressed clutch...)
But still - trany is not compleatly dead, still drivible - but to switch gears - its the acurate job now - or you will hear the GRRRRRRRshhhht sound of the angry trany biggrin.gif
Nik, GZE trany is the way to go IMHO... only problem would be to solve the Clutch/Flywheel stuff....
<<<<<< DCw / JDMart >>>>>>>
post Feb 19, 2006 - 7:05 PM
lilsteeg
Joined Jan 16, '06
From Lima, ohio
doggy doubble clutching it removes the need for synchros, back in the 30's trannys didnt have synchros so you had to put it in nutral, then let of the clutch, push the clutch back in and move it into gear, which is where they get the name doubble clutching you use the clutch twice
post Feb 19, 2006 - 7:10 PM
doGGy
Joined Oct 28, '02
QUOTE(lilsteeg @ Feb 19, 2006 - 5:05 PM) [snapback]396322[/snapback]
I know this process till death... till bare bones... Cuz i learned driving Trucks, and these trucks what i had course - aint had synchros......
I would love to see how fast you could switch the gear with double clutching... Its not the easy way too...
post Feb 19, 2006 - 9:28 PM
lilsteeg
Joined Jan 16, '06
From Lima, ohio
hmm i wonder i will have to try that tomorrow and see how fast i can do that, and that is another thing that makes the fast and the furious retarted, they said that in a drag race that you should doubble clutch, in 10 seconds i couldnt shift twice even probally
post Feb 19, 2006 - 9:55 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(doGGy @ Feb 19, 2006 - 8:04 PM) [snapback]396238[/snapback]
That would be a rather large problem... The E51/E58 trans use a different flywheel (224mm) and those flywheels are ONLY available for the 8 bolt crank 4AG. You'll need some sort of custom flywheel if you chose to run that tranny, along with custom mounts, custom axles, a clutch kit, and what not.
post Feb 20, 2006 - 1:30 AM
doGGy
Joined Oct 28, '02
QUOTE(Kwanza26 @ Feb 19, 2006 - 7:55 PM) [snapback]396400[/snapback]
good point... I knew what it doesnt fit as easy as i thought, so thanks for clarification...
post Feb 20, 2006 - 12:14 PM
Yep, good point Bee. I totally wasn't thinking and forgot about Nik's 7A bottom end with the six bolt flywheel.
post Feb 20, 2006 - 12:53 PM
nik
Joined Sep 30, '02
QUOTE(frotou @ Feb 18, 2006 - 8:27 PM) [snapback]396024[/snapback]
- 944 belt
also read this :
Keep us informed
Claude
well all this tranny talk is good but not my main problem right now but when i came to that bridge i will deal with it until then i will run the c52 for a year to see how it does and go from there
well we have to go back and redo the cam issue
it was marked for tdc and rechecked
according to toyota all the 4ag lower timing gears are the same so
i have a extra tension in my set up so my belt is routed a little differnt in one spot
but here is a little more tech stuff
I have a 2.095 lower and 4.48 uppers. With these cam gears the lower pulley should measure 2.24" not 2.095" but this was solves the difference is to account for belt stretch
944 belt
i might have a small issue of timing gear and cam gears teeth arent matching 100% still looking into this
crower 272 in and ex
my cam card is not matching the the number we got off the cams
Once again the cam card we have shows Duration @ .050 to be 224'/224' not 220'/228'. The gross lift on the card shows .321/ .321 not .374/.393 ???
so crower is not being abig help so might just run the stock cams i got from bee for now until i get the car dailed in then probably put some hks cams in but this is if we cant figure out how to get these cams to work
This post has been edited by nik: Feb 20, 2006 - 12:58 PM
post Feb 22, 2006 - 3:44 AM
Blakout16
Joined Jul 3, '04
From Yakima, WA
QUOTE(lilsteeg @ Feb 19, 2006 - 6:28 PM) [snapback]396388[/snapback]
they were granny clutchin' remember? lolol.
if they were 10 seconds or less car, they'll probably looking forward to going clutchless and just having a slap stick.
post Feb 22, 2006 - 3:59 AM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Nik, for when your C52 does go out, I'm 99% sure that you can find someone to make you a flywheel. I have heard of people welding filler rod and filling up the bolt holes, then machining it and redrilling a different pattern, maybe that would work for you. Or maybe a company like Fidenza can just make you one that will work. Either way, once you have an E51 or E58 in there you won't have a problem.
The shop doing the build sounds top-notch, I'll bet you're paying a pretty penny for it. smile.gif
Come on down to South Carolina when I move, and I'll give you a free run on the dyno biggrin.gif
-Doc
This post has been edited by Dr_Tweak: Feb 22, 2006 - 4:02 AM
Click here to see my swaps
drtweak@phoenixtuning.com
post Feb 22, 2006 - 10:46 AM
FAQdaWorld
Joined May 24, '03
From Milton, Delaware
The biggest issue with using a gze tranny is gonna be axles, flywheels and clutches can all be worked out trust me; thats the prolly one of the biggest issues with the gze swap (next to wiring and all that jazz)
-FAQ
AIM : FAQdaWorld
post Feb 22, 2006 - 11:46 AM
nik
Joined Sep 30, '02
QUOTE(Dr_Tweak @ Feb 22, 2006 - 2:59 AM) [snapback]397669[/snapback]
-Doc
what year make ans models do those two trannies come out of i think hte e51 was in the Mr2 but not sure can you send a little info my way so i can do a little research thanks Doc
post Feb 24, 2006 - 9:54 PM
97lestyousay
Joined Jul 7, '03
I will help you with a custom flywheel if you need it.
Can't wait to see that thing in action.
JDM guy made me do it.
post Feb 27, 2006 - 7:26 PM
nik
Joined Sep 30, '02
update piston should be in this week then a couple days to reassemble and get up and running than about a week of tuning to get the cam bug worked out then should be go to go so i should have it by 3rd week in march
post Mar 16, 2006 - 12:11 PM
dustin15brown
Joined Aug 17, '03
From Bloomington, Indiana
how is it coming along Nik?
post Mar 16, 2006 - 3:38 PM
nik
Joined Sep 30, '02
QUOTE(dustin15brown @ Mar 16, 2006 - 11:11 AM) [snapback]408565[/snapback]
i called the shop yesterday to check on the new pistons they wount be shipped out till the 19th so im waiting for those to come in so i can get randy his pistons and my car done and back im tired of waiting but i leave for florida the 21st until the 29th so hopefully they get the pistons in the motor reassembled the cam timing figured out and fixed and it road tuned by the end of this month once i have it back i'll post a sound clip and video and some finished pics of the motor
post Mar 25, 2006 - 11:07 PM
dustin15brown
Joined Aug 17, '03
goodluck man. I was just in florida, i got home today smile.gif be safe
Lo-Fi Version Time is now: September 20th, 2026 - 1:28 AM
