16 Pages V  « < 3 4 5 6 7 > »
> 7agte build diary, my progress so far
post Jun 3, 2005 - 11:45 PM
Mike431635
Joined Jul 20, '04
From Tampa, FL
That's a good point. I think you might want to look into that a bit farther. My 4AFE hg was flipped upside-down (thanks a ton to my dad who put the gasket on when I wasn't looking in the first place) and even though the holes matched up, they still didn't match up 100% perfect. This caused a massive oil leak and took a ton of work to fix with the motor in the car.
post Jun 6, 2005 - 3:14 PM
nik
Joined Sep 30, '02
QUOTE(Kwanza26 @ Jun 3, 2005 - 4:53 PM)
I say you should get a 4AG headgasket, to avoid hot spots in the head.  Like I said before, the reason the gaskets are different, is because the 16V head flows water differently than the 4/7AFE/20V.  The gaskets will all fit, more or less, but the way the coolant flows is the big difference.  You'll notice right away when you put the head on the block that you'll probably need to do something about the water inlet/outlet.  The 4/7AFE/20V has both inlet/outlet on the back of the head, while the 4AG typically has one by the water pump, and one in the back of the head.  Get what I'm saying?
[right][snapback]294916[/snapback][/right]
hey bee they have both gaskets there the 4ag and the 7af they just want to see the diff but were going with the 4ag wink.gif
QUOTE(Mike431635 @ Jun 3, 2005 - 9:45 PM)
[right][snapback]294951[/snapback][/right]
who are you?
post Jun 7, 2005 - 12:21 AM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Yes but Nik, did you try lining it up with the 7AFE flange? I understand it lines up pretty well to the 4AGE flange, but what about the 7AFE?
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Jun 7, 2005 - 12:36 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(Dr_Tweak @ Jun 7, 2005 - 5:21 AM)
-Doc
[right][snapback]295751[/snapback][/right]
7AFE and 4AGE ports are nearly identical. It should work the same (B series manifold mod)...
post Jun 7, 2005 - 9:09 AM
nik
Joined Sep 30, '02
QUOTE(Dr_Tweak @ Jun 6, 2005 - 10:21 PM)
-Doc
i never lined up the 7af flange just the 4ag if lines up with the 4ag then you should be fine mating the 7afe falnge with that manifold minus a little cutting wink.gif
post Jul 21, 2005 - 9:40 AM
nik
Joined Sep 30, '02
these are about 2 weeks old
the cam shaft covers will be painted to match the car
This post has been edited by nik: Jul 21, 2005 - 9:42 AM
post Jul 22, 2005 - 3:22 PM
FallenHero
Joined Dec 26, '02
From Alabama
man, is that your garage or the shop? There are parts everywhere...
post Jul 22, 2005 - 4:26 PM
nik
Joined Sep 30, '02
QUOTE(FallenHero @ Jul 22, 2005 - 1:22 PM)
[right][snapback]315594[/snapback][/right]
thats the back room of the shop i wish that was my basement well it looks like my garage tongue.gif
post Aug 18, 2005 - 10:48 PM
nik
Joined Sep 30, '02
updated pic will be up this weekend of the car and motor and some extra goodies
post Sep 6, 2005 - 3:17 PM
nik
Joined Sep 30, '02
QUOTE(celi_gt_racer @ Sep 6, 2005 - 1:11 PM)
[right][snapback]331480[/snapback][/right]
i have a few pics like 2 or 3 of them rippen the old motor out but none of the motor in the car there still working on the wiring for the sds and both stock motor and new one are sitting out so they and check the tranny out and install it on the new motor etc
waiting on a few parts like radiator and some other stuff should be in this week or early next week
post Sep 12, 2005 - 3:16 PM
nik
Joined Sep 30, '02
QUOTE(celi_gt_racer @ Sep 10, 2005 - 10:43 AM)
NOOOOOOOOOOOOOO.... well at least it's done right??.... get pics up asap... maybe vids too!  biggrin.gif
[right][snapback]332803[/snapback][/right]
nope not done new motor is in but have to change the lower part of the turbo manifold the snail part of the turbo is fitting the motor rigth where you put the filter
then they have to wire in the sds and some extra goodies one of the owners sold me a digi 7 and 2 boxs the tech guys will know what im taking about pretty much help for lanching
still have to buy a koyo rad
i need an lsd but dont know what to do
probably still 3-4 weeks out to finish
changed from steel pipe to alum 2.5 on one side and 2.75 on the other
trying to decide if i need to up the whole fuel system again IE lines external pump filter etc
right now stock lines aeromotive fuel filter ,FPR, and Walbro 255 lph pump
This post has been edited by nik: Sep 12, 2005 - 3:19 PM
post Sep 12, 2005 - 8:13 PM
FallenHero
Joined Dec 26, '02
From Alabama
if the 255 is good enough for a supra, it's good enough for a high power celica.
post Sep 13, 2005 - 4:40 PM
nik
Joined Sep 30, '02
QUOTE(FallenHero @ Sep 12, 2005 - 6:13 PM)
[right][snapback]333468[/snapback][/right]
walbro have that wine to them i wanted to go external with a box around the pump to quite the noise pretty much get a hole aeromotive fuel set up probably around 1000-1500 with everything lines fittings pump filter etc an its good up to 800 horse not saying i'll see that or anything but down the road add some race gas bigger turbo and slick and see what happens
post Sep 14, 2005 - 7:04 PM
post Sep 15, 2005 - 9:50 AM
actually nik, from what ive read, if you get an install kit for the walboro that has the foam like "sleeve" that slips over the pump, its supossed to quiet it dramaticly.
IMO the noise from the walboro isnt that loud at all, especially once your actually DRIVING the car. sure, if the car is dead silent, and your sitting at idle, and the car is low on fuel, and its a super hot day, its definetly louder than stock, but its not like its SCREEEEEMMMING loud...lol
post Sep 15, 2005 - 10:06 AM
nik
Joined Sep 30, '02
QUOTE(presure2 @ Sep 15, 2005 - 7:50 AM)
[right][snapback]334481[/snapback][/right]
thanks for the info its just my pet peve things that make noise on the inside of the car
post Sep 15, 2005 - 10:25 AM
np man, just so you know, if you want it to be SILENT aka stock, just get a supra turbo pump from the dealer, thats what art did and he loves it. smile.gif
post Sep 15, 2005 - 12:34 PM
nik
Joined Sep 30, '02
QUOTE(presure2 @ Sep 15, 2005 - 8:25 AM)
[right][snapback]334486[/snapback][/right]
yea i found out about that after i got my walbro
post Oct 5, 2005 - 9:47 AM
nik
Joined Sep 30, '02
nothing to report porject still going just slowed down because of the car being broken into but it now is perminitly on a lift inside the shop total cost for one weekend setting outside 7200 in gauges stero stuff nitrous kit etc big list i have to go down today and tomorrow and get more pics of the car inside total thrashed its a sad day frown.gif
post Oct 6, 2005 - 8:15 AM
nik, that seriously sucks big time man.
hope you can recoupe that $$ that you lost.
once you get this finished, we'll go thru, clean it up abit and get it into the stickys for sure. wink.gif
good luck man.
Lo-Fi Version Time is now: January 27th, 2026 - 2:56 PM
