Mar 1, 2005 - 11:59 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 22, '03 Currently Offline Reputation: 0 (0%) |
This noise started last night. I know I pushed my car twice to 5k. I was showing my cousin the art of 5spd. Well anyways. When I dropped him off at his house I notice that (in 1st, 2nd, and 3rd gear) I get this pulsating, hissing/swirling sound at around 3.1k until I shift to a higher gear. I pulled over immediately and reved my car by hand, and no sound. It seems to happen when I'm in motion. The noise is almost like taking a rope and twirling it real fast to get that almost whistling sound. Has anyone else had this happen? I cant seem to narrow it down to where it's comming from, since I'm the one driving. It comes from the passenger side and I dont think it's any of my belts. Any suggestions?
Mar 1, 2005 - 12:10 PM
Enthusiast ![]() ![]() Joined Aug 27, '04 From Orange County, CA Currently Offline Reputation: 0 (0%) |
Sounds like a VAC leak at first sight, but you would still hear that sound when pushing the throttle from the bay.
Check all the vac lines, and intake/exhaust bolts. -------------------- ![]() |
Mar 1, 2005 - 12:28 PM
did u hear the sound being u ? cause if u did it might be ur fuel pump .... and did by chance hit ur AC .. i did that once and was like what the fook .. that sound every time i reved i would here it then looked down and saw the AC lite one tune dit off sound was gone
Mar 1, 2005 - 2:06 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Maryland Currently Offline Reputation: 8 (100%) |
a vac line would sound like that. Also a vac line would make your car idle funny. I found a good way to figure out if you have a vac leak is to take your intake pipe off and hold your hand over the TB. the restricted air will cause the Vac line thats leaking to hiss and your idle will smooth out also. i dont know why this happns but its something my father showed my while I was having problems with my head.
hows your water temp/pump? -------------------- Member of Team 5sfTe
Mar 1, 2005 - 3:12 PM
QUOTE(macavely @ Mar 1, 2005 - 9:28 AM) did u hear the sound being u ? cause if u did it might be ur fuel pump .... and did by chance hit ur AC .. i did that once and was like what the fook .. that sound every time i reved i would here it then looked down and saw the AC lite one tune dit off sound was gone [right][snapback]251666[/snapback][/right] No sounds behind me and my A/C is off. |
Mar 1, 2005 - 3:14 PM
QUOTE(erics1one @ Mar 1, 2005 - 9:10 AM) Sounds like a VAC leak at first sight, but you would still hear that sound when pushing the throttle from the bay. Check all the vac lines, and intake/exhaust bolts. [right][snapback]251658[/snapback][/right] Everything sounded fine when I opened the throttle. It only happens when it's in motion. |
Mar 1, 2005 - 3:17 PM
QUOTE(1bwilson @ Mar 1, 2005 - 11:06 AM) a vac line would sound like that. Also a vac line would make your car idle funny. I found a good way to figure out if you have a vac leak is to take your intake pipe off and hold your hand over the TB. the restricted air will cause the Vac line thats leaking to hiss and your idle will smooth out also. i dont know why this happns but its something my father showed my while I was having problems with my head. hows your water temp/pump? [right][snapback]251706[/snapback][/right] I'll try your suggestion, but my idle was/is still flawless at 800 to 1k. |
Mar 5, 2005 - 12:59 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) |
If it's not vacuum, you might check your alternator. Put a volt meter on it and see if the voltage is fluctuating, or take it to Autozone or whatever you have there and have them test it. If you have a smooth idle and no loss in HP/Performance that'd be the next thing I check since it's so simple to replace. Then I'd check your idler pulley then your pumps.
-------------------- ![]() Project ST204.5 99.88946% complete... |
Mar 5, 2005 - 1:12 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 1, '03 From WV Currently Offline Reputation: 2 (100%) |
My mom has this problem with her Honda CRV. Her's would only do it when the AC was on. It never hurt the car(she said). She just keeps running like that, it's been over a year now like it too.
Mar 5, 2005 - 1:23 PM
Im a perfectionist. I hate having a faulty ride or having it make noises. I gave up dishoing out cash for the celi. So it's being sold. Thanks for the suggestions tho.
-Ivan- This post has been edited by LatinKraze: Mar 5, 2005 - 1:23 PM |
| Lo-Fi Version | Time is now: May 18th, 2026 - 1:59 PM |
