> I F N hate the cold weather...
post Mar 1, 2005 - 12:24 PM
macavely
Joined Nov 4, '02
It cost me some serious money ... i could have had some really nice OT today .. but last nite i went out to start the celi and nothing..... i was getting Air and Spark .. the fule pump what pumpping i could here that little bitch working ... so some here between the after the pump i'm having a fule problem.... and cause o fhte snow i can't push the car to another spot so i can workon it....its in a really bad spot right now...... i want to change the fule filter i have a feeling their is some frozen fule in there.....the temp last nite was really really cold on my street 30 degress.... damn i hate the cold ..
post Mar 1, 2005 - 2:08 PM
1bwilson
Joined Aug 30, '02
From Maryland
It takes alot more than 30 to freeze fuel. Pull a plug and give it a crank. You'll know if theres fuel getting there.
Member of Team 5sfTe
post Mar 1, 2005 - 2:16 PM
macavely
Joined Nov 4, '02
yea i know it take - 20 degress freez fuel ... unlest some water geting in the system... then u'll have ice crstals farming in the fuel .. with would me condisation in the lines somehere .. wich could happen when the temp changed as fast as it did yesterday .... and cranked it already ... did all the basic test .. fuel pump is running ok ... getting spark every where i should be ... and inectored have current... ...etc ... really looks like its the fuel filter ... should have replaced that bitch 6 months ago ..
post Mar 1, 2005 - 2:25 PM
fastgt
Joined Feb 13, '03
From California
didnt a cowboy bring you a filter?
2011 Spice Orange Mini Cooper
2011 Alpine White BMW E92 M3
gone but not forgotten
2008 Space Grey BMW Z4 ///M
post Mar 1, 2005 - 2:27 PM
1bwilson
Joined Aug 30, '02
From Maryland
QUOTE(fastgt @ Mar 1, 2005 - 12:25 PM)
[right][snapback]251714[/snapback][/right]
post Mar 1, 2005 - 3:23 PM
macavely
Joined Nov 4, '02
lol yea the cowboy brought it to me but i never installed it ...
post Mar 1, 2005 - 3:25 PM
macavely
Joined Nov 4, '02
oh and i finally got the car to start.... whipped out the heat goung... and just pointed it aht the head for a few minutes.. then around the fule rail... ( this is not the safest thing the world to do ) ... then got the boost pack cause i drained the batt last nite.... then she was chocking.. so i just tapped on the acc... then reved her to around 4k and she stayded on ...
post Mar 1, 2005 - 4:49 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
check the coil the spark may not be hot enough to ignite the gas. this was the problem on my s-10 beater i checked for spark and there was spark but it turned out to be not enough spark so i changed the coil out and bam she fired right up first crank.
post Mar 1, 2005 - 4:59 PM
macavely
Joined Nov 4, '02
yea i'm going to have to change a few things.. i have a feeling some other things are going to go wrong.. if it get cold out again like it was last nite..
Lo-Fi Version Time is now: August 27th, 2026 - 8:22 PM
