> shaking steering wheel
post Dec 2, 2002 - 9:57 PM
jumpinccv
Joined Nov 11, '02
From Ohio
i dont know if this right forum but just a little question. Ive had my celica since june, but about two months after i started noticing a little shaking in the steering wheel. I had the fronts balanced and the rest of the stuff checked. It was a little better for a awhile. Then it came back. so anyway i had to rotate my tires, did that and it helped a lot for like two weeks. now it starting to come back again, its better sometimes and worse others. And not always on rough road and smooth road too. So any info about past experiences would help. thanks guys
- jumpinccv   shaking steering wheel   Dec 2, 2002 - 9:57 PM
- - Mizuryu   the only real thing i could tell ya is check your ...   Dec 3, 2002 - 2:08 PM
- - all4sho94st   i dunno but my steering wheel kinda shakes/vibrat...   Dec 3, 2002 - 4:46 PM
- - jumpinccv   it typically does it worse when i drive faster, bu...   Dec 3, 2002 - 5:13 PM
- - SiKBOY   yeh I've got the shakes as well, had it for a ...   Dec 3, 2002 - 10:01 PM
- - BigEdge169   Do you have the stock wheels and tires on the car ...   Dec 4, 2002 - 1:09 AM
- - Benevolence   Yeah my celi shakes at around 65 mph+, had my alig...   Dec 4, 2002 - 2:36 AM
- - Russkiy   I had the same problem about a month ago. Check ...   Dec 5, 2002 - 2:00 AM
- - jumpinccv   they are stock tires and wheels, so that isnt it t...   Dec 5, 2002 - 4:22 PM
- - Zoom   Yea, I too shake at 65+. I figured it was either a...   Dec 5, 2002 - 5:08 PM
- - mynzeyes   if the car stops shaking if you let off the gas, 9...   Dec 5, 2002 - 5:42 PM
- - Benevolence   No, its not an axle, it still shakes if Im going 6...   Dec 6, 2002 - 4:09 AM
- - CDNSLEEKA   Well it looks like we have an epidemic on our hand...   Dec 7, 2002 - 11:03 AM
- - freestyler121   im not an expert here, but on my last car the ster...   Dec 17, 2002 - 11:03 PM
- - CelicaLE   I used to work in a service department at a car de...   Dec 18, 2002 - 7:35 AM
- - Blur   Damn seems like a lot of people are having this pr...   Dec 23, 2002 - 7:35 PM
- - Jason   Yeaaa.. I had this problem. Once i'd hit abo...   Dec 23, 2002 - 10:23 PM
- - SiKBOY   I went for a wheel balance the other day and a whe...   Dec 23, 2002 - 11:11 PM
- - phat94celi   Hey guys. I have the same problem. Check the tie...   Dec 26, 2002 - 8:22 PM
- - rlan214   QUOTE (SiKBOY @ Dec 23 2002, 09:11 PM)I went for a...   Dec 27, 2002 - 2:14 PM
- - rlan214   like what celicaLE said get your tires balance tha...   Dec 27, 2002 - 2:15 PM
- - CDNSLEEKA   Have had my tires balanced twice also had an four ...   Dec 30, 2002 - 4:08 PM
- - SiKBOY   QUOTE (rlan214 @ Dec 27 2002, 12:14 PM)QUOTE (SiKB...   Jan 1, 2003 - 10:45 AM
- - erc   I was just skimming through, and it doesn't lo...   Jan 11, 2003 - 2:12 PM
- - Matthew   change your power steering fluid. Trust me mine d...   Jan 11, 2003 - 2:48 PM
- - marcusk   QUOTE (freestyler121 @ Dec 17 2002, 09:03 PM) in t...   Jan 12, 2003 - 10:17 PM
- - jumpinccv   well i tried the letting the gas pedal, but it sti...   Jan 13, 2003 - 5:55 PM
- - TrDcElica6thgen   u might need new tires cause i changed my tires an...   Jan 13, 2003 - 6:30 PM
- - Cody   I was gonna say that too. When I bought my car th...   Jan 14, 2003 - 1:13 AM
- - chosen1   QUOTE (all4sho94st @ Dec 3 2002, 04:46 PM)i dunno ...   Jan 16, 2003 - 2:08 AM
- - White_GTS   I had this problem when I first got my car and I g...   Jan 16, 2003 - 12:55 PM
- - PuffDog   when i first go my celica it did that same thing a...   Jan 16, 2003 - 10:21 PM
- - JiGGa   Could be either wheel balancing or you need new ti...   Jan 17, 2003 - 2:52 PM
- - Russkiy   ok, i had my car shaking at certain speed for abou...   Mar 18, 2003 - 4:52 PM
- - 95STCelica   my steering wheel shook at low speeds -- took it t...   Mar 18, 2003 - 9:01 PM
- - mywhite94celicagt   my steering wheel shakes when i go any speed above...   Mar 20, 2003 - 9:52 PM
- - mdeuce   my steering wheel shakes too, but it's not to ...   Mar 20, 2003 - 10:48 PM
- - rlan214   QUOTE (Russkiy @ Mar 18, 2003 - 2:52 PM) ok, i had...   Mar 21, 2003 - 10:18 AM
Lo-Fi Version Time is now: August 11th, 2026 - 9:00 PM
