Mar 13, 2005 - 1:26 PM
Enthusiast ![]() ![]() Joined Jul 21, '04 From Fresno, CA Currently Offline Reputation: 1 (100%) |
how do i take out my climate control??..i took off the front screws but cant seem to take the thing out?... is there othere screws anywhere else?..or what do i have to do??..i need help thanx...
Mar 13, 2005 - 2:11 PM
this should help, http://www.6gc.net/index.php?action=howto&itu=122
Mar 16, 2005 - 1:51 AM
![]() Enthusiast ![]() ![]() ![]() Joined Dec 4, '03 Currently Offline Reputation: 0 (0%) |
yeah u need to disconnect the wire under the hood then disconnect the black wire under the carpet on the drivers side. very easy to do. just run a string through the fire wall so you can feed the wire back through easily.
-------------------- hows it taste motha f*cka |
Mar 18, 2005 - 1:02 AM
Enthusiast ![]() ![]() ![]() Joined Aug 18, '04 From NJ Currently Offline Reputation: 1 (100%) |
isnt it a pain to get everything out!! there are three plugs in the back of the control unit then the blue wire that is by the driverside carpet and the black wire that is under the hood and goes through the firewall.
Mar 18, 2005 - 1:04 AM
QUOTE(juBz86 @ Mar 17, 2005 - 10:02 PM) isnt it a pain to get everything out!! there are three plugs in the back of the control unit then the blue wire that is by the driverside carpet and the black wire that is under the hood and goes through the firewall. [right][snapback]258896[/snapback][/right] It's actually not that hard. I've done it a few times and it's not that bad once you do it once and learn how it's done. -------------------- New Toyota project coming soon...
| Lo-Fi Version | Time is now: May 24th, 2026 - 7:58 PM |
