> MAP Question, .......just look
post Mar 13, 2005 - 10:45 PM
d3monc3lica
Joined Aug 19, '04
From Maine
OK since no one decided to answer my last question, I have another, I have a MAP issue going on with the sensor and its screwing my car up, NOW when i bought my turbo kit I recieved a black box thats supposed to be a MAP sensor of some sort, now im not sure if its to replace it or not....its got
Red : +5v
Black: Ground
Green: Not Used
White: MAP pressure signal IN
Blue: MAP pressure signral OUT
NOW the instructions :
"CUT MAP PRESSURE WIRE, CONNECT WHITE WIRE IN AND BLUE WIRE OUT"
Does this completely replace the old unit or is it just a piggyback.............. anyone have pics of what exactly its replacing, or how its installed or where?
Replies (1 - 4)
post Mar 14, 2005 - 5:44 PM
erics1one
Joined Aug 27, '04
From Orange County, CA
QUOTE(d3monc3lica @ Mar 13, 2005 - 8:45 PM)
Red : +5v
Black: Ground
Green: Not Used
[right][snapback]256894[/snapback][/right]
I never cut or spliced any wires. Theres a connector on the part.
Bottom end of the map sensor had an open port for the Vac line.
Side end of sensor had the same connector as my 5SFE stock map.
Basically just unplugged both, and plugged them into the new 2 bar sensor. Sounds like you have something different. Post some pics.
post Mar 16, 2005 - 1:46 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
dude you have a supra one. wrong map. get a mr2 one or all trac one they'll both work. or if your goin piggy back just get a cheap 3 bar GM one.
post Mar 17, 2005 - 1:58 AM
d3monc3lica
Joined Aug 19, '04
From Maine
poopey.....
post Mar 17, 2005 - 2:04 AM
d3monc3lica
Joined Aug 19, '04
From Maine
Im a bit confused, can someone take a pic of the MAP for me on the stock ST, a frikin dealership couldnt describe it because the pic they had sucked, so if anyone could, please post a pic.
Lo-Fi Version Time is now: June 13th, 2026 - 3:45 PM
