> APEXI SAFC2, Tuning
post Mar 13, 2005 - 11:03 PM
d3monc3lica
Joined Aug 19, '04
From Maine
Ok so mines all hooked up to my 7AFE and its just needing to be tuned for boost soon. Now the question is.......how do i tune it, i read the damn instructions but it made no sense and the pics went all around and crazy and confused the hell outta me, so could someone sum it up on how to tune my fuel mixture by RPM..... so far all i have done is set all the sensors up so they read right and it runs fine. And as soon as i tried to change something with the ratios it made my car stall out right after i started the car......can someone clear this up?
I plan on hooking my Walbro Fuel Pump up tomorrow and thats why im asking, just want to make sure im not running too rich afterward. I dont think it will until i run larger injectors but hell I wanna play it safe.
This post has been edited by d3monc3lica: Mar 13, 2005 - 11:04 PM
Replies (1 - 9)
post Mar 13, 2005 - 11:16 PM
Doge
Joined Dec 2, '02
From Portland, Oregon
Don't mess with it... if you dont know exactly what you are doing don't even try man... theres too much money on the line. You're gonna have to take it to a shop and get it tuned... thats the only real way you'll know that you're actually doing it right as apposed to doing it all wrong... which you will definately do if you try it yourself.
post Mar 13, 2005 - 11:19 PM
d3monc3lica
Joined Aug 19, '04
From Maine
well crap that doesnt help me, i live in Northern Maine, we're talking WAY NORTH and theres no one up here that can do that......so basically im screwed?
post Mar 14, 2005 - 8:35 AM
you really need to be on a dyno with a wideband o2 sensor in to tune it. or at least on the street with a wideband. that way you can see how much fuel your removing or adding. be carefull with removing fuel with the SAFC, when you remove fuel, you add timing.
post Mar 14, 2005 - 12:20 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE(presure2 @ Mar 14, 2005 - 5:35 AM)
[right][snapback]257083[/snapback][/right]
removing fuel - more power, more chance of knock/detonation
adding timing - more power, more chance of knock/detonation
doing both at the same time with out a WBO2 and Knock sensor setup = bad things to your engine
buy a WBO2 setup with dataloging. when u get the turbo on, make a pull from 2000rpm to redline in either 3rd or 4th(you must not ahve any wheelspin) and see what the AFR is.
right before spool up, shoot for a 13.5:1 AFR, then bring it down to 12:1 at spool up/full boost, then taper down to mid/low 11's:1 towards redline.
that is if u have some thing to adjust timing, if not, you will have to run the car richer. higher AFR = leaner. lower AFR = richer.
now, to lean out/richen fuel with the SAFC, you go to the RPM point you want to change and enter a low value, like +/-2%(+ is more fuel, minus is less). do this for all RPM values that need to be altered. then make another pull and see what the AFR is like.
then repeat the whole process
its fun and a pain in the ass to road tune. when i road tune my WRX, i need a lot of room. but the i love knowing that i am chaning the way the engine runs
i dyno tuned the car last saturday. while more expensive, it was safer, and way cooler(i actually did the tuning while it was on the dyno)
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Mar 15, 2005 - 1:15 AM
d3monc3lica
Joined Aug 19, '04
From Maine
where can i buy a wideband O2 setup?
post Mar 15, 2005 - 1:17 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE(d3monc3lica @ Mar 14, 2005 - 10:15 PM)
[right][snapback]257459[/snapback][/right]
ebay has them
different performance stores sell them.
post Mar 15, 2005 - 4:54 AM
Doge
Joined Dec 2, '02
To my understanding you cannot take away fuel with an SAFC... you can only add it. I would seriously consider finding a shop as close as possible instead of buying a wideband Demon... they are multiple hundered dollars for a quality setup and it would most likely be cheaper to go to a dyno... not to mention alot safer.
post Mar 15, 2005 - 7:37 AM
doge, you misunderstood, then. you CAN remove fuel with the SAFC.
post Mar 15, 2005 - 3:02 PM
d3monc3lica
Joined Aug 19, '04
From Maine
+/- 50% at the chosen RPM settings to my understanding....
Lo-Fi Version Time is now: September 4th, 2026 - 2:52 PM
