Mar 14, 2005 - 2:43 AM
Enthusiast ![]() ![]() Joined Nov 3, '04 From Colorado Currently Offline Reputation: 0 (0%) |
Is there a sticky somewhere that I can't find that will list all the compatible injectors for turbocharged 5SFE? And do the Supra MAP sensors fit also? thanks.
Mar 14, 2005 - 2:48 AM
check the section down ...and look for the 5SFTE thread.... and next time if u have a question about engiens and or related parts... post in the proper section ..
Mar 16, 2005 - 2:06 AM
Sorry, I was tired and couldn't read so properly.. and I didn't see anything in the stickies that listed all the compatible injectors. That, and some links in the stickies don't work anymore.
Mar 16, 2005 - 1:44 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
supra maps do not fit i have 2 two prove that one. but the maps from a turbo mr2 and all trac both fit even though their diff part numbers...same thing. i have bith the mr2 one and the all trac one to prove it. also if you go piggy back you won't need the all trac or mr2 map cuz you can just get a cheap gm 3 bar one and use that with the system.
| Lo-Fi Version | Time is now: September 4th, 2026 - 4:37 PM |
