> How to tell if an E51 Tranny has LSD?
post Mar 15, 2005 - 2:41 AM
I know for a fact that not all AE101 E51 trannies are equipped with LSD. Is there a way to tell if a tranny has a LSD without tearing it apart?
Replies (1 - 2)
post Mar 15, 2005 - 2:45 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Stick in some axles and turn? I read somewhere that when you look through the diff, if there is a hexagonal shaped piece of metal across the hole, then it has LSD... I'd trust the axle method more though...
post Mar 15, 2005 - 9:15 AM
Well with the E153 trannies you can look inside where the axles goes, and if theres a bar blocking your view of the other side, it has LSD. I dont know if its the same and it requires taking out the oil and axle.
Lo-Fi Version Time is now: June 14th, 2026 - 5:49 PM
