Mar 17, 2005 - 12:41 PM
hey all, just got in from trying out "seafoam", gotta say this stuff is WILD. i been reading about it on mr2oc, and been wanting to try it, its supossed to work really well at removing carbon deposits and stuff from your engine, and its supossed to be a upper cylinder lubricant, ect. so, off to napa i went.
droped the $6.50 for bottle(i bought 2 one for the crankcase, one for the gas tank, yes you can use it in your gas take too!) and drove home. according to the mr2 guys, they are using 1/3 of a bottle in the crankcase, right into the oil filler hole, and letting the other 2/3 of the bottle get sucked into the throttle body from one of the vac lines on top, both with the engine running. so, i procedded to do it, 1/3 in the crankcase...then i checked the vac lines running into the t/b, pulled a hose off one running in and attached a long hose onto it, and slowly put the other end into the bottle, the engine bogs when you do it, so i reved it up a bit (to about 1500-2000rpm or so) till it sucked in the rest, and let it die. noticed a bit of smoke as the bottle was just about empty..and let the car bog itsef down till it shut off. then waited 15min....(finished up the install of my SAFC in the meantime noticed right away that my idle had dropped about 100rpm from 850 or so to 750 or so (according to the SAFC) and a VERY noticable increase in throttle response. they also say it helps your gas milage, tho i cant comment on that as i only just did it, but first impression is that this stuff is AWESOME! quieted up the valvetrain up a bit, definite increase in throttle response, and better milage..WOOT TWO THUMBS UP FOR SEAFOAM!!! ohh BTW heres a link to the thread on mr2oc if you guys wanna read up on it abit...gotta be a member to read it, but your all members of that awesome site anyway, right????? www.mr2oc.com seafoam thread This post has been edited by presure2: Mar 17, 2005 - 12:44 PM -------------------- Former Team 5SFTE pro member ;)
presure2 SEAFOAM Mar 17, 2005 - 12:41 PM
Digndoug Ok, so wait, what is this stuff really for? just c... Mar 17, 2005 - 12:45 PM
Coomer Haha, I got that reaction out of my mom when I use... Mar 17, 2005 - 12:50 PM
easternpiro1 hmmmm....verry intersting....i might want to drop ... Mar 17, 2005 - 12:54 PM
Supersprynt Hmm. from what Art said and now you, I'm sold.... Mar 17, 2005 - 12:59 PM
Digndoug QUOTE(Coomer @ Mar 17, 2005 - 12:50 PM)
Oh, ... Mar 17, 2005 - 1:08 PM
Supersprynt You have 2 different problems. Your burning oil, t... Mar 17, 2005 - 1:56 PM
Blakout16 yeah i havent even got to 100,000 miles yet and im... Mar 17, 2005 - 2:15 PM
Coomer QUOTE(Blakout16 @ Mar 17, 2005 - 11:15 AM)yea... Mar 17, 2005 - 2:34 PM
JoKeRkId613 A bunch of mechanic friends of mine have told me t... Mar 17, 2005 - 3:40 PM
erics1one I've heard to leave it running in the crankcas... Mar 17, 2005 - 4:03 PM
SlowCelica94 I used it as well. Even if you have no desire to c... Mar 17, 2005 - 6:09 PM
TTE Wow, I'm going to try it, but which vacum hose... Mar 17, 2005 - 9:52 PM
2003cbgts think it would harm the engine in any way? Mar 17, 2005 - 10:44 PM
dustin15brown So anyone else try it and their thoughts? I'm ... Mar 18, 2005 - 12:47 AM
erics1one QUOTE(dustin15brown @ Mar 17, 2005 - 10:47 PM... Mar 18, 2005 - 11:02 AM
presure2 if you guys are looking for reviews from more peop... Mar 18, 2005 - 5:29 AM
Supersprynt Where'd you guys pick it up? Levine and Autopa... Mar 18, 2005 - 8:44 AM
presure2 i got mine from napa 6.50 per bottle Mar 18, 2005 - 8:45 AM
Newbie I used the vacuum hose that came off from the IAC.... Mar 18, 2005 - 9:51 AM
TTE My Webpage
I gave it a try and put 2 bottles betw... Mar 19, 2005 - 7:42 PM
tengys So which seafoam you are talking about??? Seafoam ... Mar 21, 2005 - 1:35 PM
bloodrain Im not 2 fond of pouring liquids into my engine :-... Mar 21, 2005 - 1:45 PM
slipgun Very interesting... do you all think its worth run... Mar 21, 2005 - 5:21 PM
Coomer QUOTE(tengys @ Mar 21, 2005 - 10:35 AM)So whi... Mar 21, 2005 - 5:30 PM
Consynx i demand more smoke!!!!
lol, next ... Mar 21, 2005 - 6:13 PM
Coomer QUOTE(Consynx @ Mar 21, 2005 - 3:13 PM)i dema... Mar 21, 2005 - 6:18 PM
ghostdog we should have a officially sanctioned 6gc seafoam... Mar 21, 2005 - 6:18 PM
Consynx hmmm...
touche' Mar 21, 2005 - 6:33 PM
qban537 lol ...i think i like my odds here.... Mar 21, 2005 - 6:45 PM
Jeremy1210 I think either of my 2 celica St's will win th... Mar 22, 2005 - 12:16 AM
TRDDawg I added it to my gas, oil, and t/b. My idle dropp... Mar 24, 2005 - 12:50 PM
Consynx pssh, i had NO SMOKE...
until i drove away after l... Mar 26, 2005 - 6:35 PM
Delta_Phoenix I used 1 bottle between the throttle body, gas tan... May 10, 2005 - 2:08 PM
FreddyTheOthaMeat BG products makes a similar product, its just a ca... May 10, 2005 - 2:29 PM
lagos if you just put it in the crank case, and gas tank... May 10, 2005 - 3:20 PM
FAQdaWorld I'll prolly run this through the gze in a whil... May 10, 2005 - 4:53 PM
mentat im tempted. Though i just swapped my oil like 2 d... May 10, 2005 - 5:24 PM
FAQdaWorld QUOTE(mentat @ May 10, 2005 - 5:24 PM)im temp... May 10, 2005 - 6:04 PM
mentat Thats bad.... That click could be your engine abou... May 10, 2005 - 6:50 PM
FAQdaWorld Pray?
Seriously tho, you should get it checked ... May 10, 2005 - 7:36 PM
mentat daaamn. Guess i'll be considering a 3sgte for... May 10, 2005 - 7:40 PM
easternpiro1 im still weary about this... my car has 184,000mil... May 11, 2005 - 11:48 AM
FAQdaWorld In no way should you take my word as gospel, so ju... May 11, 2005 - 3:47 PM
lagos rod knock dosnt click. its more like a rattle soun... May 11, 2005 - 3:48 PM
mentat Lago's,
Thanks i'll do that. My car soun... May 11, 2005 - 5:00 PM
CelicaST18 while we're talking about engine problems/smok... May 11, 2005 - 7:38 PM
lagos check for leaks under the car...or oil anywhere on... May 11, 2005 - 8:02 PM
CelicaST18 there aren't any leaks...no drops on the floor... May 13, 2005 - 7:32 PM
Bigmeanbulldog55 I know this has been old for a bit, but I'd ju... May 23, 2005 - 7:04 PM
Hanyo how long does the smoke last?
i dont want to get ... May 23, 2005 - 7:50 PM
Bigmeanbulldog55 QUOTE(Hanyo @ May 23, 2005 - 8:50 PM)how long... May 23, 2005 - 8:17 PM
chicklover345 just used it but it didnt smoke as much as you all... May 29, 2005 - 8:31 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 27th, 2026 - 4:59 PM |
