Mar 17, 2005 - 4:47 PM
![]() Enthusiast ![]() ![]() ![]() Joined Sep 17, '03 From Tampa FL Currently Offline Reputation: 1 (100%) |
My horn isnt working. i push it and the relay clicks and nothing. fuse is good. could it be a bad relay? I cant find the horn either. my manual doesnt say where it is.
-------------------- -97 Celica ST
-2001 Celica GTS dk blue mica 100hp per litre (GOT LIFT?) |
Mar 17, 2005 - 4:50 PM
QUOTE(ArizonaRed @ Mar 17, 2005 - 1:47 PM) My horn isnt working. i push it and the relay clicks and nothing. fuse is good. could it be a bad relay? I cant find the horn either. my manual doesnt say where it is. [right][snapback]258639[/snapback][/right] The two horns are in the front of the car, in front of the A/C condenser between the two high beam headlight assemblies. I take it from your want-to-buy posts that you got into a front-end collision? It may have broken them off. -------------------- New Toyota project coming soon...
Mar 17, 2005 - 5:03 PM
The only two things I noticed were the 2 airbag sensors I took off. at least thats what i think they were, they had a yellow wire. I got this car as a cheap salvage that ran into a ditch. the horn worked after the accident but i started taking the airbag system off and then the lights and then...... no horn.
Mar 17, 2005 - 5:40 PM
ok figured it out they are the flat black disks that i somehow took off and misplaced. thnx
Mar 20, 2005 - 1:53 PM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 22, '04 From USA Currently Offline Reputation: 3 (100%) |
welcome to atlanta where the playas play!!!!
| Lo-Fi Version | Time is now: July 12th, 2026 - 2:56 AM |
