Mar 17, 2005 - 10:46 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 9, '05 From Oakland, Cali Currently Offline Reputation: 46 (100%) |
hi,
is teh emblem on the rear has holes behind it?....want to take off all emblems on the rear....including the rear spoiler.... -------------------- ![]() |
Mar 18, 2005 - 12:12 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Hollywood, FL Currently Offline Reputation: 0 (0%) |
spoiler = holes, emblems = no
-------------------- To live, is to suffer
To survive, thats to find meaning, in the suffering.... ![]() |
Mar 18, 2005 - 12:19 AM
Enthusiast ![]() Joined Jan 5, '05 From Santa Ana, OC So Cali Currently Offline Reputation: 0 (0%) |
the toyota symbol has holes behind it.. but the words don't
spolier is a project of its own -chris |
Mar 18, 2005 - 12:26 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 19, '04 From Scottsdale, Az Currently Offline Reputation: 2 (100%) |
Your going 2 have 2 weld the holes closed.. You can use putty as long as your car dont thump da bass
Mar 19, 2005 - 3:01 AM
QUOTE(madmods @ Mar 18, 2005 - 12:26 AM) Your going 2 have 2 weld the holes closed.. You can use putty as long as your car dont thump da bass [right][snapback]258868[/snapback][/right] thanx ya.... -------------------- ![]() |
Mar 30, 2005 - 9:59 AM
Enthusiast Joined Mar 28, '05 From Mini-US Currently Offline Reputation: 0 (0%) |
-the solid way, the long way!
-this method, is not to take off your liftgate or trunk. and the holes will be sealed shut. -takes time(solder, drop by drop) to fill the emblem holes, you got to go to the local hardware store and ask for water piping lead-free solder, solder grease(very important, it makes your solder stick to your desired surface). also pick up a hand-propane like @ checkers,autozone ect. sand off your surface, 80 grit sandpaper. take out your third brake light off from the car. clean the surface(s), outside and inside. put solder grease on the outside of the holds and inside(liftgate, trunk). put alot of grease, w/o it the solder will not stick. stuff some rags or "shop-towel brand" paper behind the two holes. becareful, not to let the rags or paper towel get in the holes. lift up your liftgate(hatch) or truck to the max. stand on something tall, use the hand-propane to heat up the lead-free solder. slowly start to drip the solder from the outside of holes then to the center. don't worry if the solder is mounting up to a big lump. you'll have to sand it down...w/ 36 grit sand paper. do the same to the other hole. remember to slowly sand. some excess solder will fall and slide off the liftgate. care the solder are hot! when done, clean surface off, wipe off grease, use rubbing alcohol. apply very------>very thin layer of light putty! sand with 2000 grit sandpaper. wetsand better! don't rush the sanding! thank you for your time and post(s) -usdm_at200 This post has been edited by usdm_at200: Mar 30, 2005 - 10:01 AM |
Mar 30, 2005 - 10:05 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 3, '02 From Va Team 6gc Currently Offline Reputation: 1 (100%) |
thats cool, i've never heard of anyone using solder for emblem holes. thats pretty good idea.
-------------------- ![]() All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
Mar 30, 2005 - 10:10 AM
I prefer the duct tape I have over the hole, lol j/k, good idea on the soldering, never thought about that, and since I work at radioshack and have access to %30 discount on the stuff maybe I'll give it a go.
Mar 31, 2005 - 11:05 PM
Enthusiast ![]() ![]() Joined Nov 29, '03 From Hampton, VA Currently Offline Reputation: 0 (0%) |
Yea I just welded up the holes for the emblems and spoiler. I guess soldering could work too though.
| Lo-Fi Version | Time is now: August 25th, 2026 - 3:35 AM |
